question on fork tubes
Old Jul 30, 2012 | 05:36 PM
m i k e's Avatar
m i k e
Default question on fork tubes
im changing out stock hd springs puttin in progressive springs
got all apart except the tube it self, do you take a screwdriver and open it up or is there a tool?
fyi pulled the 12 mm allen fromn underneath got the 2nd spring out& piece that hold tube n fork together, there is somethin else in there & i have a seal to install.
thanks
mike
Old Jul 30, 2012 | 06:20 PM
jreichart's Avatar
jreichart
Not sure if the rocker is the same, but I carefully pried the dust boot off with a small screwdriver, remove the retaining spring clip underneath it, and with the bottom damper bolt removed, use the tube as a slide hammer to pull the seal free. Everything should then come apart. Again, this was on my softie, and I know those rockers are slightly different.
Old Jul 30, 2012 | 08:33 PM
m i k e's Avatar
m i k e
jreichart
You da man! goin to try that now.
Old Jul 30, 2012 | 09:10 PM
Joe What's Avatar
Joe What
yes there is a clip that retains the seal in place..
Old Jul 30, 2012 | 11:10 PM
m i k e's Avatar
m i k e
ok i got the dust cover off, ( small punch& rubber mallet)
then you take a flat head screwdriver and carefully take out funky o ring
JekyllnHyde
Jun 19, 2019 02:26 PM
lmz5150
EVO
Sep 17, 2018 06:47 AM
BaggerBill103
Mar 30, 2016 07:08 PM
Road Star
Aug 3, 2014 01:02 PM
ShiftyCapone
Feb 16, 2014 11:30 AM
