Just curious, do you know what type of oil was put in the tranny when it was changed?
If not, I'd suggest that you drain the tranny and put the H-D transmission oil in it.
Should cost less than $10 and then at least you'd know that you have the proper oil in it.
I'm old fashioned and I don't buy into this "3 hole" oil garbage.
I use motor oil in the motor, primary oil in the primary, and transmission oin in the transmission.
I only use H-D transmission oil in all of our bikes, except for one that has the Baker DD6, because they recommend Redline Shockproof in their products.
Not too many years ago when the synthetic oils came along, every H-D mechanic and/or service manager I talked with said no way in h**l should put that stuff in my motor.
Now that they sell it for $10 bucks a quart, it's the best thing since sliced bread!.
Someone said to check your clutch adjustment, I suggest this also. Even though it may feel fine that is what will change the most when it warms up. On mine the previous owner screwed up and locked the jam nut on the wrong side of the cable so it slowly adjusted itself enough that it would get hard to shift (especially neutral and first) after it warmed up. Once I pulled out the manual and adjusted it correctly the world was good again.
I was just looking for the simple operator error. Being a 30 year mechanic all you need is a good Harley service manual. It's probably not the oil since it does it hot, not cold. There is no adjustment for transmission except shifter position and that is for your foot. If it not an out of adjustment clutch or warped steel disk in the clutch, it's probably from a bent shift dog or shift ratchet in the transmission. These things are pretty tough but shifting hard how you described in first post while not moving will bend them if gears are not aligned. Those big square dogs are what must be in alignment since all the gears are always in mesh. It's not borken gear teeth.
Bent forks,worn dog teeth, shifter pawl adjustment are all unlikely if it only does it when it is hot. I would looking seriously at the clutch. Clutch plates can get sticky in heat. Make sure there is not to much fluid in the primary. Make sure you are not running motor oil in the primary it has detergents in it which can also lead to sticky clutch plates. Food for thought.
Just picked it up 2 weeks ago so can"t say just happened or not. Also a mechanic of 34yrs. Makes no sense to me but Harleys and Chevy's are two totally different beasts! When it's cold all is good, when it's hot (No first gear) unless you give it time and pray as you shift it.
If you have been a mechanic for 34 years then bear with me and you should be able to follow this. Regarding actual mechanical linkage, etc. heat will have very little effect on the shifting. Therefore you need to consider any other items where heat can have a significant effect. Heat will reduce the viscosity of the oil in the transmission however this would make it easier to shift rather than harder. This pretty much eliminates the transmission itself. If it did the same thing when it was cold then it could be different. The only thing left then is the clutch which does expand when it warms up. This is significant enough that the service manual specifically mentions it. The clutch on these has fairly tight tolerance and it only take a small adjustment to put it too tight where heat will make it hard to shift. Keep in mind that the clutch lever itself may feel just fine yet it may not be disengaging completely. I know several of us have mentioned this already however you don't seem to be paying attention. Have you actually pulled out the service manual and checked the clutch adjustment? If not then you cannot eliminate that as a possible cause. Especially when that is the one item that can be effected enough by it warming up to do this.
BTW, there are two parts for the adjustment. One is at the clutch itself to adjust how tight it is. The other is the cable to adjust how fast it engages when you pull the lever. Either one could be out of adjustment enough to cause this.
