Questions about fuel
The bottom line is that pump premium fuel has no downside, unless one needs to pinch pennies. Guessing wrongly in the opposite direction can have huge and much more costly consequences.
I wouldn't dream of putting anything less than premium in my supercharged Corvette, my blown+nitrous dragboat, or my Harley. We put regular in the Jeep, the Nissan, and the lawnmower.
REGULAR VERSUS PREMIUM GASOLINE
Regular Gasoline Has As Much Merit As Premium Gasoline
"Put a tiger in your tank," says a classic advertising tagline. In today's motoring world, what kind of fuel grade will have the power to place a beast in your gas tank?
The answer, according to experts who study fuel efficiency in detail, is both regular and premium gasoline. And it would be a waste of money to favor premium over regular, especially in these times when gasoline prices are high, according to the experts.
Virtually nothing is gained by filling up with a premium or more expensive grade of fuel than the vehicle manufacturer has recommended, the experts say. And many of the same experts explain that drivers may not lose much performance from their cars by using a lower grade of fuel than recommended by the car manufacturer.
There is little difference in energy content of regular versus premium gasoline. They both contain about 111,400 British Thermal Units of energy per gallon.
The price difference, however, between the fuel grades is anywhere from 20 cents to 40 cents, depending on where you live in the United States. The experts' consensus goes against the long-held belief by thousand of drivers who fill up with premium only, or on every third or fourth trip to the pump. The idea is to fill up with premium every so often to clean out the engines or rev up the performance of older engines.
But according to the experts, this practice is like tossing quarters in a wishing well, since most engines are designed to operate on relatively low-octane regular unleaded gasoline.
Octane is defined as a fuel's resistance to knocking. There is no benefit if the octane is higher than what the engine needs. Engine knock occurs when fuel in a combustion chamber ignites before it should. This disrupts the engine's operation. But electronic knock sensors are now common and have nearly eliminated engine disruption.
The American Petroleum Institute says if you find that your car runs fine on a lower grade, there is no sense switching to premium. The Institute recommends following manufacturer's recommendation, but even those manufacturers say that it is more of a suggestion than a command.
For more about this subject, see the excellent article "Fact or Fiction?: Premium Gasoline Delivers Premium Benefits to Your Car Exploding the myth that premium gasoline delivers better performance in the average automobile" by David Biello on Scientific American's website at: http://www.sciam.com/article.cfm?id=...tion-premium-g
It's true that BTU content is roughly the same for the various grades of fuel. But that doesn't mean that the grades can be used interchangeably. What you get with premium gas is greater detonation resistance, and usually a better detergent package. Detonation is a major cause of engine damage.
Many modern computer engine management systems can sense detonation, and adjust parameters to control it and prolong engine life. They do it by reducing power or fuel economy. If an engine is designed around a low octane fuel, these adjustments seldom come into play. But as far as I know, the Harley engine management system doesn't include detonation sensors yet, so the ability to compensate for low quality fuel is very limited.
On top of that, Harleys (except for the V-Rod) are air cooled, so temperatures can't be controlled very accurately. A fuel which is adequate under most situations may not be adequate to protect from engine damage when the motor gets a little hotter than usual.
One big challenge with understanding detonation is that people often don't realize when engine damage has been caused by it. It can cause everything from accelerated wear (fewer miles before needing a rebuild) to banging out the bearings on the bottom end.
(Note: I edited this post from the original version to tame it down.)
It does not "clean up" an engine. In fact the higher octane that you use the less of it will burn during the combustion cycle and will carbon up the motor faster.
It you have cams and higher compression then yes, higher octane is needed.
But a normal HD Twin Cam runs great on 87 octane and in the mountains 85 is the best to use.
(Warp Factor) If have no clue where to start with your comment?
