Please define 'lugging the engine'
Old Aug 20, 2012 | 09:22 AM
glideridemike's Avatar
glideridemike
Originally Posted by Dynalmadman
Okay okay okay okay, I apologize to the linguistic perfectionists. I do have a concept of the term lugging. Mea culpa (look it up).
But lugging the engine on this FatBoy would be vastly different from lugging on my old shovelhead, or my Triumph Daytona, or my old BMW 533i.
The Triumph wouldnt get comfortable until above 5 or 6k. The FatBoy would just explode at those revs.
So to rephrase my original for all the English professors,
In your experience with the 2011 softail engine and gearing, what would you consider the average shift points and cruising RPMs?
And Thank you to those that gave me some useful answers. Just trying to keep her running smooth.
Michael
Old Aug 20, 2012 | 09:42 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by Poor_Dog
For the same reason I never compression brake my bike as it has the same effect of throwing the whole load back on the crank that it wasn't designed for.
You transfer the entire weight of the bike plus it's momentum to the crankshaft when you brake like that. There are times you need to use the compression such as when braking on a steep incline, however it's generally frowned upon as a regular braking technique.
That's a piece of cake for the crankshaft, compared to the loads it sees under even light throttle. And on a motorcycle, you need to go through every gear in between to reach first anyway, so it doesn't cause the additional wear that downshifting through each gear would when approaching a stop in a car.
Old Aug 20, 2012 | 11:54 AM
TravelingBiker's Avatar
TravelingBiker
Originally Posted by dickey
Nonononono...brake pads are much cheaper than crankshafts.
So you're saying slowing your bike by downshifting ruins your crankshaft?
Old Apr 11, 2014 | 08:12 PM
Browning, nb's Avatar
Browning, nb
If this is the case I guess I learnt something today.
Old Apr 11, 2014 | 08:22 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just stumbled on to this old thread, but I`ll throw this in...
Slowing the bike by downshifting will do no harm to the crankshaft.
In my opinion, guys that talk this junk science are the guys who have never actually worked on the internal parts of an engine, and have never learned the proper way to operate a motorcycle.
Old Apr 11, 2014 | 11:16 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I keep mine over 2000rpm and usually shift at 2500 in any gear. Under 2000, I don't even think about giving it gas. Down shift and then gas it.
Old Apr 11, 2014 | 11:33 PM
2black1s's Avatar
2black1s
... For the same reason I never compression brake my bike as it has the same effect of throwing the whole load back on the crank that it wasn't designed for...
That's interesting... Maybe I'm reading you wrong, but by "compression braking" I'm thinking what you mean is by slowing the bike with a lower gear before using your brakes. I was always taught that's the proper way to brake.
Did I misunderstand you or have I been taught incorrectly?
If you're afraid of uneccesary wear on your crankshaft because of engine braking you should probably park the bike. Of course there can be some wear attributed to engine braking just like with every other function of the bike, but I would consider it more normal wear and tear than uneccesary wear and tear.
Old Apr 14, 2014 | 08:19 PM
Aaronstottle's Avatar
Aaronstottle
Wow....
I was taught that engine braking was proper both on the bike and in a car.
It goes right along with the technique called "rev matching".
A lot of guys rev their engine a bit in between gears just to hear it.
I rev mine to match the rpms of the gear I'm going to downshift into...
This is, as I was taught, a proper technique.
I'm sure I'm not the only one who has learned this. It's been in practice since the first
manual transmission was invented....
Old Apr 15, 2014 | 07:30 AM
glideridemike
Originally Posted by Aaronstottle
Wow....
Yep, but its always been known its not good to lug a motor too.
Old Apr 15, 2014 | 08:28 AM
E8USMCRET's Avatar
E8USMCRET
When I was a kid in HS my Father was teaching me to shift on an old beater. When I asked him how do I know when to shift his answer was "the engine will tell you when".
I lugg it rarely these days but when I do it's pretty obvious and I hear those words in my head.
