Engine noise
Old Sep 25, 2012 | 06:32 PM
  #41
soft 02's Avatar
soft 02
Originally Posted by FroggyFatBoy
Detroit ?
old Cummings. Individual head 6 cyl. Just changed the one. Komatsu TD25 Dresser. Size of a Cat D9.
Old Sep 25, 2012 | 06:36 PM
  #42
FroggyFatBoy's Avatar
FroggyFatBoy
that reminds me of some of the pistons laying around the shop where my dad worked.. he worked semis for 45 yrs.. i remember as a little kid i was always amazed at the shear size of the eng, trans and diff parts..
Old Sep 26, 2012 | 05:47 AM
  #43
Warp Factor's Avatar
Warp Factor
You said you may have overfilled the eng oil. its possible you aerated/foamed the oil and put the eng in self destruct mode. that sucks..
How does overfilling with oil aerate/foam the oil on a dry sump motor?
Old Sep 26, 2012 | 07:15 AM
  #44
Jackie Paper's Avatar
Jackie Paper
Know you know that but just to answer out loud (for the first poster only since that was one of his concerns) since the oil pump return rotor is much larger then the pump pressure side it will not. The crank shaft flywheel rotors never spin in oil..UNLESS the return side of the oil pump has a problem. Then that of course would be another problem.
russrudder
Screamin Eagle CVO Models
Sep 5, 2012 05:23 PM
Blueharley
Oct 1, 2010 06:54 AM
1peter
Jun 5, 2009 11:10 PM
zyepod
Oct 22, 2008 08:18 AM
travisd
May 21, 2006 03:50 AM
