Rocker Tank
Old Aug 28, 2012 | 11:04 AM
'71's Avatar
'71
1st Gear
Default Rocker Tank
Hello, new here to the site.
I've got a bag load of stupid questions and no Nomex fire resistant suit so try to go somewhat easy on me please. Thanks
Was wondering if:
You could take the center chrome trim from a deuce (order part) and swap it with the one on the rocker, as they are the same tanks?
Is the rake for the forks on most harleys the same or do they all differ ? ( ie dyna WD as compared to a softail, Deuce or Rocker).
Does anyone make a fender for the Rocker that is similar to the ones on the V-Rod muscle or the 883 iron with the LED's build in and under the curve of the fender?
Thanks again, Murray
Old Aug 28, 2012 | 12:33 PM
rockerz's Avatar
rockerz
Was wondering if:
Don't have an answer for the tank question, but interested in an answer. I haven't heard of anyone trying it.
Rocker has more rake than others, if looking for different trees try Rich at Bitchin seat company.
There are different fender options out there. Heartland kit ( you will need air suspension to make it work best), they have an LED option in their struts, cut stock fender & put LED's under the lip like I did or get LED's for the stock signals. You will have to relocate plate to the side.
There are so many theds out there to search. The Rocker guys are extremely helpful on this site as you will soon find out.
Good luck with your mods, keep questions coming (as no question is a dumb question). Also send pics as you go.
Old Aug 28, 2012 | 01:01 PM
'71's Avatar
'71
1st Gear
Thanks a million for the info Rockerz.
Old Aug 28, 2012 | 09:16 PM
m i k e's Avatar
m i k e
michapop put a blakline trim cover on his looked pimp
https://www.hdforums.com/forum/membe...247-093-2.html
there is also a link from austrailia hd forums
https://www.hdforums.com.au/Default....&postid=374312
rake differs on all scoots some same some different
then you could have someone make you a front end
joe what made his 1st fender with a light on it /under it looked great
https://www.hdforums.com/forum/membe...rear-view.html
check out his pic album
Old Aug 29, 2012 | 01:13 PM
Rail's Avatar
Rail
Deuce dash will fit fine but you have to do more than a straight swap.. You need to change speedo, plug ends on wiring harness, decide what to do with ignition switch, etc
Old Aug 29, 2012 | 08:13 PM
'71's Avatar
'71
1st Gear
I couldn't have hoped for any better answers. Thanks you gentlemen for finding out exactly what I was wondering.
Once again, thank you!!!!!!!!
Jaxx
Jan 20, 2010 11:40 PM
kylant
Feb 25, 2009 01:22 PM
saintslax11
Jan 31, 2009 07:21 AM
flyingace
Mar 19, 2008 12:00 PM
benman
Mar 18, 2008 02:36 AM
