The raw aluminum air cleaner that came with my stage 1 kit is ugly and stick out on the motor. I'd like to paint it black and wondering if anyone has done this and what they used.
Use Masking Tape to cover: The two "O" Ring surfaces, The Throttle Bore Gasket surface, the Air Filter sealing surface and the "Clean Side" of the Air Filter area. Trim the Masking Tape with a Razor Blade if you are particularly **** (like I am) about how perfect the job needs to be.
I used high temperature Wrinkle Finish Black Spray Paint. Came out perfect!
