CV carb problem
Old Sep 8, 2012 | 03:52 PM
CJax92's Avatar
CJax92
Default CV carb problem
My '92 EVO CV carb spits gas out the ventura under a load, ie. 70mph in 5th gear. when running easy it doesn't happen. I have tried 3 dif. carbs and they all do the same thing. I have set the float by the book and reduced the float level down a little a couple of times, no change. Any Ideas?
Old Sep 8, 2012 | 04:22 PM
oct1949's Avatar
oct1949
U might Ask this in the EVO section... they might be able to help U better and faster.
No more time than U spend in here U may not even know there is one so I'll post the link for Ya..
https://www.hdforums.com/forum/evo-classic-models-84/
OR,,,, U might even do a search to find the answer... U'll have to read a little to learn. Click below to find out.
http://lmgtfy.com/?q=Harley+Evo+carb+spitting+out+gas
Old Sep 8, 2012 | 04:45 PM
CJax92's Avatar
CJax92
Default Thanks!
Your right I didn't know about the EVO section. Thanks!
Old Sep 8, 2012 | 11:50 PM
DDuess's Avatar
DDuess
Do you have straight pipes on it. Sounds like reversion, it is a pressure pulse reflecting back to the cylinder. Normally seen on long straight pipes, could also be rpm dependent on a particular cam grind, late closing intake timing.
Old Sep 9, 2012 | 07:33 AM
CJax92's Avatar
CJax92
Stock mufflers on down pipes that were shortened about4". I don't know anything about the motor. The bike was a basket job with no idea about mileage or mod's., comp. was right on. Seems stock as far as the power and the way she runs. I have put about a thousand miles on it, runs good.
blair
Sep 10, 2013 01:54 AM
1sandking1
Jul 5, 2012 10:12 PM
chipdavey
Exhaust System Topics
Jan 21, 2011 10:32 PM
8super2glide
Shovelhead
Aug 30, 2010 03:09 PM
craiger62
May 26, 2008 10:59 AM
