Mikuni carbs?
Old Sep 12, 2012 | 01:55 AM
deedee4150's Avatar
deedee4150
Default Mikuni carbs?
So i got me o softail duece 2003 carb.."..thinking of putting a mikuni on it...do they make a diffrence or is it a waste of money?i made some custom exhausts with baffles..will i see any diffrence..or should i instal cams and a new coil and ignition?
Old Sep 12, 2012 | 07:03 AM
magnum629c's Avatar
magnum629c
The carb does help I would never go back to stock. 289$ from eastern performance.com I did cams years later and that made a even bigger jump well worth the money and sound
Old Sep 12, 2012 | 10:01 AM
Lundee's Avatar
Lundee
For a stock bike? Just put a dyno jet kit in. cv40 is a great carb. Unless you plan on some serious motor work.
Old Sep 15, 2012 | 11:42 AM
drugar's Avatar
drugar
Just put one on my '03 Electra, I couldn't keep it from coughing back thru the carb. & popping on decell. I tried every thing, finally bought one at bike fest in Salisbury, MD. I told him what I had( SE intake & SE exhaust) and he rejetted it, set the accelerator pump, needle position and approxamate idle adjustment.Brought it home , put it on, took it for a ride, fine tuned the idle mixture & it hasn't popped or coughed yet. I'M SOLD!
Old Sep 16, 2012 | 08:09 AM
heybaylor's Avatar
heybaylor
the stock CV can be tuned ....so can the mikuni..
either one works fine when tuned to the bike .
Old Sep 16, 2012 | 09:00 AM
feguy1's Avatar
feguy1
Mikuni is my choice of carbs. I put them on all of my carbed bikes.
Old Sep 16, 2012 | 09:50 AM
mrlexus's Avatar
mrlexus
Best carburetor for a modern Harley, hands down. You will not regret it. Much crisper throttle response with the direct operated slide. You might gain a couple horses at WOT, but it will feel much stronger at part throttle twists and accelerating.
gmly
Exhaust System Topics
Jun 12, 2013 09:05 PM
FL-kruzen
Aug 20, 2012 07:48 PM
Recon72
Dec 31, 2010 03:28 AM
justanotherjim
Aug 29, 2010 05:30 AM
Shrink
27
Dec 10, 2009 05:06 PM
