Blackline wiring problem ??
Old Sep 23, 2012 | 12:42 AM
Doc71's Avatar
Doc71
Stage II
Default Blackline wiring problem ??
Everytime I put on an after market item which involves the rear light wiring, the taillight/brake/signal does not work when I'm done. Anyone else ? 2011 FXS Softtail Blackline. Just wondering if there is a model problem or a mechanic problem. (The mechanic would be me.)
Old Sep 23, 2012 | 01:03 AM
Rakthi's Avatar
Rakthi
You might have a problem because of the can-bus wiring on the 2011 and up models.
Don't know of a work around that one. Maybe someone else knows?
Old Sep 23, 2012 | 07:21 AM
Tracker56's Avatar
Tracker56
yeah, not simple electrical circuits anymore. All computer controlled and balanced. Modifying the circuit with cut and splice will sometimes cause it to fail. They're designed for "approved" plug-n-play accessories only.
Old Sep 23, 2012 | 07:05 PM
goats's Avatar
goats
i changed the wire route on my rear lights (made it easier to remove fender whenever i want) and had to extend the wires to do so, cut splice solder and tape/shrink wrap...no problems for me.
might want to double check the connections you made, did you solder them?
Old Sep 24, 2012 | 12:41 AM
SoftailBrian's Avatar
SoftailBrian
Cut and spliced for the install of the LED tailights on mine, works fine.
Old Sep 26, 2012 | 06:10 PM
rebeltruce's Avatar
rebeltruce
I completely remove the rear tail light and changed over to to LED's on a license plate mounted on the swingarm pivot........lotsa of cutting and splicing....twisted, soldered and shrink wrapped no problems at all.
dschulz23
Audio Systems
Jul 5, 2017 06:02 PM
sbeast
Aug 1, 2014 08:29 AM
JerryDinMD
May 17, 2014 11:04 AM
wil261
Aug 20, 2013 06:32 AM
hdemt
Jun 11, 2012 02:12 PM
