Crossbones Riser issue
Old Oct 2, 2012 | 08:57 AM
Hedghawg71's Avatar
Hedghawg71
Default Crossbones Riser issue
I have read most if the threads here on this forum and the answer I am looking for isn't really there. I put 16 inch apes on my Bones with the already stripped and helicoiled risers that i wish I could throw in my recycle bin and be done with them. The bushing flex is horrible on these especially in a Texas head wind and I was looking for other options as to something that could replace the stock risers completley (black/chrome dont care) that didn't have bushings and would solidly mount to the top of the tree with no flex at all. Like trying to bend a man hole cover no flex... ;-) I tried the firmer bushings, that was $13 dollars straight to the "**** Me" fund and I know there has to be other options out there. Something that looks like the stock one somewhat. Hell, even a safe way to modify the stock ones rigid could also work. Any help would be appreciated.
Last edited by Hedghawg71; Oct 2, 2012 at 11:53 AM. Reason: Cell phone typos... :-)
Old Oct 2, 2012 | 09:13 AM
hspring03's Avatar
hspring03
Good N Tite Poly bushings from alloy arts
These things never flex.
http://www.bkrider.com/BKRider/skuse...eria=C01040174
Old Oct 2, 2012 | 09:47 AM
seehogs's Avatar
seehogs
I have had luck shortening the bushings or adding a washer to the shouldered bolts,
depending on what type you have. This puts more pressure on the bushings and helps.
Solid bushings are probably the only way to get rid of ALL the flex.
Old Oct 2, 2012 | 11:58 AM
Hedghawg71's Avatar
Hedghawg71
Kinda thinking if there isn't a riser that would completely replace the current ones or a one-off idea on this the maybe a mix of both ideas above could work. Hmmm...
Old Oct 2, 2012 | 01:54 PM
1 2 many's Avatar
1 2 many
Smile
Thats what I am running. Art alloy makes some good stuff... I was having the same issue with my apes... Also what I did was re_tap the risers to the next size up. And a dded some shim between the bars.. I made the shims out of tomatoe cans. Couldnt get the rite thickness out of aluminum
Old Oct 2, 2012 | 03:04 PM
travis dasher's Avatar
travis dasher
Drill and Re-tap the stock mounting holes top and bottom riser. Then, Drill the riser in the center down to the bar, Tap the riser. Screw a bolt into the riser and into the bar. BAM no more flex. Only cost are the bolts. No more "**** Me" fund.
Old Oct 2, 2012 | 10:24 PM
Hedghawg71's Avatar
Hedghawg71
I took them back off this afternoon after I got home from work and ended up doing kinda what Seehogs said, but with 4 counts of a federal offense involved! There was a quarter on my work bench and while I was sitting there I dropped the quarter into it just playing around while I thought and pondered how I was going about this being that if it went lower the studs would interfere with the handlebar mounting... and it happened to sit at the seat of the top bushing in the riser just about right. So, I took 4 of those, drilled a hole 1/2 inch through the center of all 4 and dropped 2 in the top of each riser, then the bushing, then I sat it all back down on the stud and I torqued her back down. It cost me $1 and it is solid as a rock. No flex. I suspect the bushings got real tight and the quarters had a hole drilled in them that was just big enough for the riser stud to go through to also limit movement alot as well. I appreciate it Ya'll.
Old Oct 3, 2012 | 04:26 AM
Redder's Avatar
Redder
a good option.
wild ones springer risers.
they are a rigid mount...no bushings. $ but rock solid.
Old Oct 3, 2012 | 06:01 AM
Toy_Jon's Avatar
Toy_Jon
Originally Posted by Redder
a good option.
Ive got the WildOnes Risers and there AMAZING!!!!!!!!!
no flex at all and my bars havent moved since day 1, there are expensive
but worth it to me.
Highly recommend them!!!!
Old Oct 3, 2012 | 06:11 AM
brettnbama's Avatar
brettnbama
I use the alloy art goodentites as well...
bigbadpoppa
Jun 29, 2019 06:12 PM
KEG
Nov 16, 2013 10:52 AM
acman308
Feb 25, 2013 06:23 PM
jousley
Nov 2, 2009 09:58 AM
jbphoto
Aug 20, 2008 02:00 PM
