Does anyone know if the stock Fatboy Lo exhaust (pipe+mufflers) would fit on my '04 Fatboy? I found the Lo exhaust on ebay - and thought it would good on my old bike. Has anyone tried fitting newer pipes on an old 88 CUI?
You may need the bracket that goes on the frame and the exhaust. Then again the frame was changed in 07 so it may not line up exactly. This is what wrenching is all about
Lets put it this way.. I took a V&H exhaust from a 2000 Nighttrain and bolted it up to my 2010 Lo, all i had to do was make some 1/8" spacers for the mounting bracket to ensure I had clearance from the swingarm. Yes they will fit, but you may have to do some fiddling with the frame bracket, that's all. also, if your '04 isn't fuel injected, you'll need some O2 port sensor plugs for the holes on the pipes.
Btw..how much are they asking for the exhaust? I've got my stock exhaust from my '10 Lo up in my attic with only 700 miles on it, maybe I can make you a better deal.
