Can Bus extended
Old Oct 29, 2012 | 07:51 AM
pimentahd's Avatar
pimentahd
Stage I
Post Can Bus extended
I am from São Paulo, Brazil, I own a Fat Boy 2012 and I would like to change the hanblebar for a new one with 15", can I cut the wires from switchs handlebar and extend these and weld again? Thanks
Old Oct 29, 2012 | 08:16 AM
Rodzilla6's Avatar
Rodzilla6
I did not change all the wires on mine, but I changed out 2 switches on the handlebar and cut and spliced them with no issues. Do a nice clean, weather protected job and you should be OK. Per some advise on here and my gramps early training, I offset the splices (don't bunch them all together), solder the wires together cleanly and seal the splice with liquid tape or shrink tube real good. Good luck.
Old Oct 29, 2012 | 08:18 AM
lgenf's Avatar
lgenf
it may be better for you to consider buying longer cables, that may be a much cleaner look
I know there is over 100% import fees for Brazil, but if you have the extra cash it would be a cleaner look
nevets61
2014-2024 Touring Models
Mar 18, 2019 10:34 AM
2014streetglide
Apr 9, 2011 05:18 AM
Techknowguy
May 10, 2010 09:33 PM
Redleg by God!
Mar 29, 2010 08:22 AM
BlackFLHR
May 19, 2009 03:10 PM
