Lowering
Old Nov 7, 2012 | 10:12 AM
Wide_Open's Avatar
Wide_Open
Originally Posted by 24v
There is no way this can be true. Both the bolts and the collars do the same thing, just with a different piece of metal.
I would find it hard to believe as well. Mine is in the shop now having performance work done and I got to talking to the owner about lowering it. I told him I wanted to go with the lowering collars but was having a hard time figuring out how to do it with my Sears yellow stand. He offered to do it but with the problems in the NE couldn't get the Dead Creek Cycles kit so I went with the bolts. I'll report back later on the ride.
Old Nov 7, 2012 | 12:17 PM
Midgard's Avatar
Midgard
The ride quality difference expressed by a few members could be attributed to a few things. First would be where the preload is set on that particular shock. Then wear and tear, and age of parts, could certainly come into play. Also, individual tolerance for ride could be a factor also. The amount of lowering will come into play as well, the closer you are riding to the bumpstop the harsher the ride will be.
To the OP, save your $ and buy the shotgun. The ability to have a smooth ride an almost any ride height is awesome.
Old Nov 7, 2012 | 12:24 PM
24v's Avatar
24v
Originally Posted by JustDave71
how does this shotgun shock respond to hard jolts, or rather, the second hard jolt?
I responds great. That is the beauty of the shotgun. There are 2 switches, so essentially you can put air on both sides of the piston in the shock. This way you can set ride height, and comfort.
So, if you have it set firm, it should handle great, then when you want the Old Lady on the back, you can smooth it out for her.
Old Nov 7, 2012 | 02:34 PM
Benway's Avatar
Benway
The ride is harder with the bolts/collar because you've taken 2" out of the shock travel, so it bottoms out easier. Simple as that.
Myself, I ride solo 98% of the time, so the 2" bolt route works perfect for me. If I wanted to ride full height and cushy, I would be riding a stock softail. I have no need or want to ride up high when it's just me. (my last bike was a chopped Triumph hardtail, so you know where I'm coming from)
Sure, if I was rolling in $$ I'd go ShotGun, no doubt, but until that happens, I'll get buy for $16.
Old Nov 7, 2012 | 03:57 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
Each to their own.
I put the lowering bolts on my Train 5 or 6 years ago, lowered the *** end about 2".
Bike looks good, and handles great.
I've had a LOT of passengers on the back, and my best girl has been keeping that space warm for over a year now.
NEVER a complaint from any of them, and I've never bottomed out.
Like I always say: bikes, seats and shocks are like asses, they're not created equal...
I know guys who can't ride across town without an Ultra, and I know women who ride Sportys and hardtails to Daytona...
Old Nov 7, 2012 | 09:42 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
What hard jolts?
Old Nov 8, 2012 | 04:37 AM
RANGER73's Avatar
RANGER73
I did the lowering bolts, as I don't have 1250 to drop on shocks, spent a little more and bought the entire lowering shock to simplify install. I lowered it to much and was hitting the stops on hard quick bumps so I had to raise it 1" to get back the travel. It's my understanding that you have to remove the Shotgun to drain the tranny as it blocks to drain plug.
Old Nov 8, 2012 | 04:50 AM
ryanek9freak's Avatar
ryanek9freak
You don't have to remove it, just take out one bolt and let it pivot and hang, doesn't add but 5 minutes to a trans fluid change.
Old Nov 8, 2012 | 05:15 AM
RANGER73's Avatar
RANGER73
Not on mine, 94', there's a cross brace on the frame or the swingarm (can't remember which) that would prevent the shock from pivoting far enough.
Old Nov 8, 2012 | 05:25 AM
moomba's Avatar
moomba
Are the bolts difficult to install. The collars look simple, but have not found instructions on the bolts.
Thanks for the advice
