I installed a brake/turn signal module to get running tail lights on my '05 Heritage. It's not working. Is there anything I need to do besides plug in the module to the wire harness?
Do you have any other plugs inline like a brake strobe or anything? Any corrosion on the connectors, loose connectors? Checked all fuses?
If not then its possible you may have the wrong model for your bike or it is simply a defective unit. Did you buy it new or used?
What brand and model number? They are all plug and play normally.
