Made the switch
Old Nov 21, 2012 | 10:14 AM
ogh11756's Avatar
ogh11756
Default Made the switch
I made the switch Saturday from Sportster to Softail Deluxe.
What a difference in ride, feels like i am riding on a cloud :-)
2006, 88 EFI with cams & pushrods, stage 1 air, fuel management, D&D 2:1 exhaust.
Don't have the service manual yet but getting one.
Loving it but have a few questions about the transition.
1] Can i downshift without the clutch like i did with the Sportster without doing damage?
2] The starter seems to slip, grind, & skip a beat when starting. My logical mind pictures missing tooth in the ring gear but not sure.
3] Starter also seems to be working hard to turn engine over.
Any help or advice would be appreciated.
Old Nov 21, 2012 | 10:18 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I don;t know about downshifting without the clutch. Call me logical but I always use the clutch.
Has the engine been built to a 95" with heads?
How is the battery voltage?
Old Nov 21, 2012 | 10:41 AM
ogh11756's Avatar
ogh11756
As far as i know, it has not been bored to 96, and has original heads.
He only mentioned the cams & push rod work on the engine itself.
The battery in my tester is dead so i wont be able to check that until tonight.
What readings should i be getting from the battery? while running & not running.
Old Nov 21, 2012 | 10:52 AM
GinsengSullivan's Avatar
GinsengSullivan
Grats on the Deluxe! You should love it, at least I know I love mine lol
Old Nov 21, 2012 | 11:13 AM
KumaRide's Avatar
KumaRide
1) You can down shift without clutch
2) Not sure without listening
3) Try starting it in neutral. My 88" is also cammed and it turns over easier in neutral, especially on hot days.
Welcome to the softails!
Old Nov 21, 2012 | 11:24 AM
ogh11756's Avatar
ogh11756
Thanks, Always start in neutral i gear up while it is warming up.
Thanks for the welcome
Old Nov 21, 2012 | 12:31 PM
scannerman's Avatar
scannerman
a friend had the same starting problem, it was a worn ring gear
Old Nov 21, 2012 | 12:58 PM
ogh11756's Avatar
ogh11756
Thanks for the info. Going to need a service manual for that fix!!
Old Nov 21, 2012 | 02:19 PM
oct1949's Avatar
oct1949
Originally Posted by ogh11756
switch from Sportster to Deluxe.
All Good So far
Still sounds pretty Good.
Really Smart move
Now Ur showing a little NON wisdom... EVEN shifting U Sporty without Using Ur clutch wasn't GOOD for it....
Sounds like U start is going Bad or other issues.
Check out Ur Battery if its still the ORG one, then its time for new one, Also Battery cables for being dirty or loose bolts (common issue).
Enjoy Ur new/Used Lux.. but please don't ever ask again if U need to use Ur clutch to shift..
Old Nov 21, 2012 | 02:32 PM
Village Idiot™'s Avatar
Village Idiot™
Check your injectors. '06 bikes may still have the 8 degree injectors in them. Upgrading to the 25's will help with the slow starts. I did that to my Deuce and it starts much easier.
