Service manual
Old 11-26-2012, 12:38 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
Default Service manual
Hello all, Does your factory service manual or clymers manual explain the need for more primary oil when removing the primary cover as oppesed to just draining and refilling? I've been watching U-tube videos and somebody said to put 40 something ounces if you took cover off but 38 if you were just draining it. I know, I know...buy a manual you say. I'm holding out for funds.
Old 11-26-2012, 01:24 PM
fdb2007's Avatar
fdb2007
fdb2007 is offline
your owners manual has the procedure and the right qty. I don't have any idea about how you would change the oil without taking the primary cover off, short of turning your bike upside down and filling it from the drain.
Old 11-26-2012, 01:28 PM
95"06Nightrain's Avatar
95"06Nightrain
95"06Nightrain is offline
varying amounts because if you were to just pull the drain plug you'll get most of the oil out, but there will always be some left in, trapped along the internal ridges. If you pull the cover off, the little bit that was stuck in will come out
Old 11-26-2012, 01:47 PM
Snowyone's Avatar
Snowyone
Snowyone is offline
I just drain it with the plug and fill it up till the oil hits the clutch basket. Think it was 32 oz. It's good to pull the primary cover off every other time just to ck things out or if there is an excessive amount of filings stuck to the magnet on drain plug. With the auto chain tensioners life is usually pretty good in the primary. My .02
Old 11-26-2012, 02:47 PM
fdb2007's Avatar
fdb2007
fdb2007 is offline
When you say primary cover are you talking about the whole outer side of the primary or just the derby cover?
Old 11-26-2012, 03:44 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
Additionally, my Harley Factory manual for 02 Softail gives a fluid range. Without opening the book, I think it states 24 to 28 ounces. As Snowyone stated, you must also visually inspect the fluid level.
Old 11-26-2012, 05:51 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
FDB2007, I was talking about the entire outer cover. Pulling the derby cover wouldn't affect how much comes out of the drain. I will be replacing my outer Primary cover due to some road rash a previous owner caused and wondered if anyone else had heard it's a different amount of oil to go back in. Hopefully I will get my manual before I undertake this.
Old 11-26-2012, 05:53 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
I guess a better question is where the fluid level should come up to on the clutch basket when i refill it. That's also up for debate i guess. Mine's a 93 heritage if it matters.
harris48cars
09-24-2010 06:04 AM
aeromass
Oil Archive (no new posts)
08-21-2010 07:55 PM
buickboy
09-02-2008 06:56 PM
Unclenuts
10-08-2007 06:12 AM
20NightTrain03
06-15-2007 05:51 PM
Quick Reply: Service manual
