Hey folks, first post in this forum, thanks for having me.Ive got a 2005 night train (fuel injected), bassani stepped pipes, intercooled procharger, and a power commander. Heres the problem. Riding one day and it popped coming off full throttle, did it a couple times at the stop light then seemed to clear up. A few days later, same thing. THEN....while coming home it started popping, losing power, and barely holding idle. Tried restarting it and only got a weak effort and then nothing. Ive since replaced the coil and plugs to no improvement. Power commander is still lighting up. ANY help, thoughts, advice would be greatly apperciated. Thanks and glad to be part of the forum.
So the bike is supercharged? Check your compression...just a tad lean with a blower will burn a hole in a piston in a hurry
Yes its supercharged. Was just out looking this thing over and noticed a bit of oil from the front rocker box cover. Didnt see it at first, the SC units pipe and pop off valve are hiding it....guess its off the shop and hopefully only a few paychecks away from running.
Stupid?....LOL The way I see it... just a good reason to throw a big bore kits and cams at it. I know,I know, Im a gear head at heart. Ill just keep my fingers crossed. Thanks for the warm welcome. Tons of knowledge on here. thanks for the input guys.
