Help with rush install on Slim
*Edit* I figured that out finally. Now Im getting a leak in the pipe right at the clamp. How far onto the pipe does the clamp need to go? I believe I have it right at the edge of the slipon itself.
Not sure if you know, but Rush recommends a much higher torque for the clamps than the manual recommends. I believe it is around 60-65ft pounds compared to the factory 40ft pounds.
As far as clamp position, I placed mine flush with the end of the slip on itself and have had no problems.
Hope this helps.
Hope this helps.
If I had mine to do over I would use a heat resistant tape or sealant.
I was getting decel pop & a little discoloration on the muffler.
I cranked it up to over 80 which did stop it but should not have to
go that high IMO
go that high IMO
Use new clamps, many say you dont need to. Clamps should be about 1/16" and no more then 1/8" from inlet end of slip on. Use a high temp sealer and make sure muffler is on as forward as brackets will allow, any leak at your connections will cause a decel pop.
I did not use sealant or tape, just new clamps at the higher torque value. Did this with both my Rocker and Blackline and have never had any issues with decel pop.
Enjoy your new mufflers!
Thanks for choosing Rush and I'm glad you got it sealed. New clamps are recommended because they can stretch and become egg shaped. Once that happens they will not uniformly apply pressure around the muffler inlet. We also recommend 60 ft lbs due to a thicker gauge steel than stock mufflers.
Ryan
Ryan
So it looks like I fixed the leak. I cant see it anymore. It was very visible at one time. I havent gotten to ride it yet but I do get some popping when I pull the RPMs up and let off. Is it normal? Im not planning to get a fuel remap anytime soon. Sounds perfect at idle.
jblank37
Jul 20, 2008 09:32 PM
