resetting ECM
Old Dec 26, 2012 | 04:09 PM
cgmartine's Avatar
cgmartine
Smile resetting ECM
Is there a way to reset an ECM to original factory specs?I have a 2006 Heritage Classic bought used. It had Vance and Hines mufflers, but now I have a set of original stock mufflers from a Deluxe. I don´t know if this bike ever had any other upgrades which were removed, plus other things done, like Stage 1 download, remapping, etc. I want to return to the point of origin because the engine does not run as good as I think it should. Will a tuner tell me what is now programmed in the ECM?I don´t want to make any changes until I now what has transpired. Does this make sense? I don´t plan to make any other modifications, I just want it to have the same specs as the day it rolled out of the factory, then I´ll start fresh.
Old Dec 26, 2012 | 11:23 PM
XARAN's Avatar
XARAN
Yes you can flash the ECM back to stock either take it it the dealer and pay them to do it usually about $ 150 or buy a flash tuner like the HD SERT,SESPT, TTS or Power Vision and do it your self. The HD tuners With e software (cd) have various tunes on them and tuners like TTS or the Power Vision have many places or users that can supply you with a copy of their stock MAP. Even by changing the pipes etc back to stock the bike can run better with a MAP different than the stock EPA lean set up
My suggestions call Jamie at Fuel Moto and buy a Power Vision he can then set you up with a base line MAP for your needs and you can either run that , self tune doing data logging or take it to a Dyno
Old Dec 27, 2012 | 12:57 AM
KumaRide's Avatar
KumaRide
Their was a service notice on 06 bikes to replace 8 degree injectors with 25. The most noticeable symptoms are rough starting or running when cold. May or may not be applicable. You can visually check your injectors.
Old Dec 27, 2012 | 10:37 PM
cgmartine's Avatar
cgmartine
Red face
Thanks. I´ve been contemplating getting a tuner. Will it work on a bike without 02 sensors? The pipes are from a Deluxe, but it is a Classic. The Deluxe pipes had the bungs, but I had to plug them up. The Power Vision sounds great, but if I can´t use all of its capabilities with my setup, what´s the use¿
Old Dec 28, 2012 | 02:29 AM
olongapo1's Avatar
olongapo1
There are many tuners on the market. Some allow you to re-map the Harley ECM and some mount permanently to, and piggy-back off the ECM. On one of my bikes I use the Vance and Hines Fuel Pack which is a piggy-back device programmable without a separate laptop computer. It's sufficient for stage 1 but not much else.
One system that interest me is the ThunderMax. Google them and check it out. Several of my Bro's are using it. Completely replaces the stock ECM.
hillcountryflt
Oct 26, 2011 05:54 PM
Martimus
Sep 12, 2011 01:36 PM
FastGraf
Feb 11, 2011 12:11 AM
dankfoot
Aug 27, 2010 09:53 AM
SaltyHawg
Apr 1, 2010 11:19 PM
