Will 2011 Tank fit a 2007 Fatboy?
Old Jan 3, 2013 | 12:03 PM
SmittyFXDL's Avatar
SmittyFXDL
Default Will 2011 Tank fit a 2007 Fatboy?
Posting this for a friend who has a 2007 Fatboy. He just purchased a tinset and turns out its a 2011 tank and fender set. Everything looks the same except the 2011 doesnt seem to have a vent tube anywhere and there is a bolt sticking up where efi would go inside tank.
Will this still fit if he used a vented gas cap? Im attaching both tanks so you can see the green tank has a bolt and the yellow has none inside efi cutout.
Thanks for any advise.
2007 tank
2011 tank with bolt inside
Old Jan 3, 2013 | 01:56 PM
Rbs68cgr's Avatar
Rbs68cgr
I put an 08 tank on my 07 fxstc & the fuel float bracket won't fit cause newer ones had a smaller clip. The front wheel is offset with 07 also. I think the offset affected fat boy also. 07 was a messed up year. Good luck.
Old Jan 3, 2013 | 05:33 PM
ShortsNSandals's Avatar
ShortsNSandals
Not with out a complete new Fuel injection system. I have an 07 Heritage with 09 tins and had to replace everything in the tank. I spoke with 3 different shops and there is no way around it.
Old Jan 4, 2013 | 07:05 AM
SmittyFXDL's Avatar
SmittyFXDL
What did a new EFI run ya if you dont mind my asking.
Old Jan 4, 2013 | 08:10 AM
ShortsNSandals
Around $500.00 If I recall and that was at a deal.
DMan4968
Feb 7, 2018 06:22 AM
norcal
Oct 18, 2014 10:08 PM
chrisxdrew
Dyna Models
Nov 4, 2012 02:40 AM
INTHERED
Nov 11, 2011 06:57 PM
JJSS
Oct 28, 2011 11:18 AM
