Stupid, probably simple headlight problem
Old Jan 9, 2013 | 08:15 AM
rancid13's Avatar
rancid13
Default Stupid, probably simple headlight problem
I'm not electrically inclined. I removed my rear wheel last week and in the process broke the wire for my license plate bracket light(it's mounted to the axle). No biggie. But it was too close to the LED though to splice it so I bought another light. Waiting for it in the mail now. However, I cranked the bike yesterday and noticed that my headlight wasn't on. My brake light works, instrument cluster works. No headlight though. What could the issue be? Thanks
Btw, the headlight bulb was just replaced about 3 months ago.
Old Jan 9, 2013 | 11:16 AM
Das_Fatboy's Avatar
Das_Fatboy
Have you tried to see if the light works on hi beam? I would start with the headlamp and make sure it is working...just because it is relatively new does not mean it is ok.
Old Jan 9, 2013 | 11:20 AM
Motown Strag's Avatar
Motown Strag
Did you check the fuse? Its under the seat in the fuse block.
Old Jan 9, 2013 | 11:27 AM
soft 02's Avatar
soft 02
fuse...
Old Jan 9, 2013 | 11:48 AM
rancid13's Avatar
rancid13
Thanks, I'll check the fuse after work. If it's a blown fuse, could the tag light being disconnected have anything to do with it? Or was it just it's time to blow out?
hrnttwk
Jun 12, 2012 01:40 PM
jcmusic
Jun 17, 2010 04:27 PM
Trenton Original
Apr 6, 2010 08:39 PM
kk6pg
Aug 13, 2009 10:49 PM
mattia
Jun 3, 2008 02:52 PM
