Dimension verification request
Old Jan 9, 2013 | 09:42 AM
HDCustomFabrication's Avatar
HDCustomFabrication
Question Dimension verification request
Looking to verify a couple dimensions on a 00-later Softail detachable side plates.
I have a rigid plate and need to verify if the detachables have the same bolt pattern and what the offset is on the vertical.
The rigid plate has a 9.25" center on the mounting holes, and I believe the detachable have a 1/2" offset to the outside.
Please verify or set me straight.
Thanks in advance.
Old Jan 11, 2013 | 09:54 PM
snip0721's Avatar
snip0721
ive got both. they both use the same mounting holes, and the offset is the same on both. not sure what your looking to do, but everthing should be interchangable. steve
Old Jan 12, 2013 | 09:15 AM
HDCustomFabrication
Thanks for the reply.
We are developing a new secure side plate to use with out adjustable tourpak mount.
How wide is your sissy bar where it mounts? Do you use the same one for both mounts?
Old Jan 12, 2013 | 10:00 AM
snip0721's Avatar
snip0721
yep...i can mix and match between rigid and detatch, and use either hd sissy bar. i have a very low bar with a small pad, and a taller bar with a larger pad. since i bought the ultra, i run the fatboy solo, and rarely use either. you want the width of the bar, or the side plates?
Old Jan 12, 2013 | 10:37 AM
HDCustomFabrication
The actual outside width of the sissy bar itself where it mounts to the side plates.
Old Jan 13, 2013 | 10:34 AM
snip0721's Avatar
snip0721
8 7/8"
Old Jan 13, 2013 | 10:43 AM
HDCustomFabrication
Thanks for your help, appreciate it
Old Jan 13, 2013 | 03:05 PM
snip0721's Avatar
snip0721
no problem. i looked around on your site today. you've got some nice looking stuff. you ever think about offering a quick detach set-up, or adjustable set-up for the tour-pacs on the touring models? harley wants a small fortune for them, and if you could beat their price i think you'd have good luck. steve
Old Jan 13, 2013 | 03:28 PM
HDCustomFabrication
just need to get the dimensions and we can make it. We hope to have it available very soon.
Old Jan 19, 2013 | 04:09 PM
HDCustomFabrication
Thought I would post this to show the ease of assembly and installation of the adjustable tourpak mount.
rwoolworth1
Jul 1, 2019 07:48 PM
str33t303
Feb 15, 2015 09:14 AM
littledragon
Apr 1, 2014 07:55 PM
wcm413
Jul 12, 2011 01:35 PM
RudeDog
Nov 27, 2008 06:03 PM
