Hello all,
First time to post here as you can usually find the answer or info. if you read past questions and answer. But, I can't find it so here goes.
I have two Softail Deluxe's, mine is a 2009 the ole lady's is a 2011(of course).
Both bikes show to hold a little over 3 qts with filter change. I can only get about 2 qts. In them with the filter change.
Am I missing something here.
Only thing I can figure is the specs. show 3.3 qts. with filter change is for a new install.. I am guessing there is about a quart left in the motor.
Could some one please clue my dumbass as to weather I am doing it right or not.
This is a great site, I had not been on a Harley for almost 40 years and bought two about 8 months ago. And the information on here is endless. Hope to meet some of y'all in the future maybe at the State Hog Ralley here in San Antonio, Texas where I live.
There's more in the crankcase of the engine that doesn't come out when you drain it. So yeah, you won't get it all out unless you do a full oil cycle (which involves draining the oil that you can, leaving the old filter on, fill with new oil, disconnect oil return line from the oil tank, attach a hose to that oil return line and then starting the engine to cycle the old oil out from the engine in to a bin, once it runs clear, re-attach the oil return line, then top it off with fresh oil)
I think I only put like 2 3/4 qts back in on my last oil change.. something like that.
i put 2.5 quarts in, start and let run for a bit, and re-check. usually have to add a small amount. DONT OVERFILL. it will puke out the extra from the fill tube.....not fun.....steve
drain oil, replace oil filter, add 2.5 qts of fluid. Done. Remember when you check the oil level the engine should be hot and on the jiffy. Checking it cold will give you a false reading.
Same as most do, I put a little in the filter before I install it (don't take as long on restart to refill) then I add 2 1/2 qts in tank.
Then I start her and check to make sure see the oil is about 1/2 between the low and full mark.
Next time I run her up to full temp then I put her on the Jiffy stand and recheck and add more if needed to maintain the level at 1/2 between the full and low marks.
3 qts will probably be too much to add to the tank,, if U added too much, U can take a turkey baster and suck some of it out.. don't ask how I know that will work...
Had the same issue for my first two oil changes - 3 too much, 2 1/2 too much, now I put 2 in and top off. Also, if you use synthetics the oil level doesn't change much hot or cold.
Conventional or synthetic doesn't matter as far as getting different readings hot or cold. The softail oil tank is above the crankcase and gravity will allow oil to drain from the tank to the crankcase while sitting; some more than others. That is why checking oil cold gives false readings. The amount of oil in the tank will depend on how long the bike has been sitting and/or how much has drained into the crancase.
There will be anywhere from 18 to 24 ounces of oil remaining in the motor after the oil has been drained from the tank, plus whatever is in the oil cooler/lines if a cooler has been installed. A complete oil change is the only way to remove that oil. Certainly not necessary but if a complete oil change is what one wants, there are kits to do that.
Do you use the HD tool for removing the oil line from the tank?
If not can you please tell me how to get the line out without tearing up the retainer.
You don't need the "HD" tool unless you want to pay too much for something..if you've got a PepBoys or Autozone near you, go rent an oil line disconnecting tool or a 3/8" air conditioning line disconnecting tool. They both rent tools for free.
If you just want to take it apart, try to pinch the black tabs together and gently pull it out. sometimes it may be a little stuck and give you some issues, but it's not that bad
