Engine exaust studs....need help
Old Feb 3, 2013 | 11:42 AM
fatboyopen's Avatar
fatboyopen
Stage IV
Default Engine exaust studs....need help
upon installing my new pipes i must have striped the threads out inside the engine how do i fix this and can it be done by me or do i need someone else (shop) to do it
Old Feb 3, 2013 | 01:56 PM
bigblock59's Avatar
bigblock59
helicoil kit. best of luck!
Old Feb 3, 2013 | 03:05 PM
Lundee's Avatar
Lundee
Yup helicoil, your lucky it stripped in the head. Not to difficult, if you can get on it without pulling the head.
Old Feb 3, 2013 | 03:48 PM
oct1949's Avatar
oct1949
Read through this link,, U'll learn how and what to do.l.
Remember Ur not the first to do this.
A lot of help in these sites below..
https://www.google.com/search?source...6a991549296b91
Also remember to use Google in the future.. Its Ur friend on finding help..
Old Feb 3, 2013 | 06:58 PM
fatboyopen's Avatar
fatboyopen
Stage IV
awsome thanks guys i do appreciate it
Old Feb 3, 2013 | 08:55 PM
djl's Avatar
djl
A Timesert would be a better approach; it's a permanent repair. A heli coil might work but you have to worry about it coming out of the thread bore with the next time you remove the pipes. I use red Loctite when installing helicoils to mitigate against that happening but the heat in the cylinder head will melt the Loctite so that won't work very well in that location.
You can try a heli coil and if it does come out, replace it with a Timesert. It goes without saying that be careful drilling out the thread boss, whichever method you choose. It is a tight working area, you want to drill straight and keep the thread bore concentric.
Old Feb 6, 2013 | 06:57 PM
fatboyopen's Avatar
fatboyopen
Stage IV
right on now for the next ?.....what would casue the carb to sneez with a smoke like air coming outta the carb i replaced the old carb cover which was completed open with no filter with a cone housing with filter i still have the breathers on it but the breather bolts are smaller then the old ones.....would this casue the engine to puff smoke after start up then die or could it be my carb is flooded...........ive recently redone my whole bike and am working out the kinks
Phunky One
Dec 11, 2018 07:49 AM
Ballfreak
General Topics/Tech Tips
Oct 15, 2014 09:47 AM
darens12
EVO
Aug 25, 2012 09:50 AM
TWIN CAM 96
Apr 29, 2011 07:23 PM
tunil
Aug 15, 2009 11:21 PM
