Bulbs are fairly bright. And each of the lenses have 2 allen bolts holding them. Bulb change is easy. I have the black 3* with signals on my Deuce. Get a lot of compliments on them. Your bike is gonna look sweet.
Hey man, thanks for the input, question, does the lower triple tree set closer to the fender than the stock ?
Jeri, your bike was another inspiration in the Pro One and relocation kit
Thanks, just made my day! Your scoot was cool way before mine though!
Regarding the trees, yes the pro ones are further apart, and the bottom sits closer to the fender. Here's some comparo pics:
Thats the same headlight on the same mount in both pics, probably the best reference to distinguish the difference. Essentially, the distance between the trees will be almost exactly the length of the neck. You planning on changing out the bottom race to the hidden stop? Don't forget to order the pro one riser bushings, as they are proprietary and the only ones that fit their trees. Good luck, any questions just ask! That scoot gonna look even more killer than it already does!
Thanks Man for the Info, Bike is being disassembled as we speak
Kudos to Adam from TimeWarp Choppers, he did a Great Artistic Job on the first paint, but when I told him that I was not too enamoured with the green and asked for a full change of direction, the dude stepped up like you won't believe.
This is the older Green paint scheme that we rolled back.. he went insanely artistic on it, the fact I did not the color does not take away from the stunning job
