Cam Question
Old Feb 5, 2013 | 12:25 PM
CBurch's Avatar
CBurch
1st Gear
Default Cam Question
I have a 06 night train and I would like to change the stock cams. I would like a little more power and to many to chose from. Any recomendations?
Old Feb 5, 2013 | 01:43 PM
IronAss's Avatar
IronAss
I put the SE 211's in mine and have been happy. Nothing neck snapping but I get a little better power in the mid and top range from them.
Old Feb 5, 2013 | 02:19 PM
QC's Avatar
QC
If this is all you're going to do your motor, my suggestion is Andrews 26. Don't forget to inspect your chain tensioners while you're in there.
And welcome to the Forum from Colorado!
Old Feb 5, 2013 | 07:12 PM
Sgt_Jim's Avatar
Sgt_Jim
whoa whoa whoa... there's a million cams out there, but you need to be more specific of what KIND of power you're trying to find. Do you want your power to come on straight out from the hole and keep it in the low-range (2500-3500rpm)? or do you want your power to come up higher and give you that kick in the *** when you're trying to pass someone on the highway (3500-4500)?
Correct me if I'm wrong, but the 06 Train has a 96", right? Are you planning on opening it up to a 103" or higher?
and if it has an 88", are you planning on taking it to 95"/98"?
Do you plan on doing some headwork and changing your compression at all?
If you can answer those things, you can narrow down your choices a great deal.
Old Feb 5, 2013 | 07:29 PM
Dan33klein's Avatar
Dan33klein
X2.. Need to know what your goals are.
Old Feb 5, 2013 | 07:55 PM
Heritage_and_Bones's Avatar
Heritage_and_Bones
With what you've given us so far, all of us could tell you what cams we have in our bike and whether we're happy with them or not. All that would tell you is if those cams in your bike would make us happy, not you. Cams are part of a performance recipe, and the important questions, asked above by Sgt Jim, are where in the RPM range do you want the power, and do you intend to stop with cams, or do you want head work, and/or a displacement increase, too? Oh, and is the bike injected or carb'd? Some cams work well with one and not the other.
Old Feb 5, 2013 | 09:53 PM
magnum629c's Avatar
magnum629c
Andrews 21 .....tons of torque if thats all ur.going to change u cant beat the andrews 21
Old Feb 5, 2013 | 10:06 PM
blindrocket's Avatar
blindrocket
Not to hijack the thread, but this has been in my mind as well and I didn't know where to begin with the many cam options.
I'm planning on soon getting an 03 Night Train with carb'd 88b motor.
Want to upgrade the cam to start, but would not mind taking it to a 95 at some point down the road. The tensioner or whatever will need changed at some point as well, from what I understand. It currently has 14,000 miles.
Thanks
Old Feb 5, 2013 | 10:40 PM
klf33's Avatar
klf33
I am happy with the Andrews 37, they are also good if you decide to later pump up your Engine to 95", 26 and 21 are more suitable for bigger heavier bikes (or so they say), the 37 opened the bike pretty nice for me .
Old Feb 6, 2013 | 10:18 AM
Wide_Open's Avatar
Wide_Open
I have the CR 575's in mine. Very happy with them.
http://www.cycle-rama.com/CRProducts.html
