New guy has blinker problems
Old Feb 6, 2013 | 06:47 PM
BrusterAZ's Avatar
BrusterAZ
Default New guy has blinker problems
Greetings all,
Since I am a new owner of a 93 Softail, I thought I would join the forum to gain from the vast knowledge that this sites members have to offer.
My right signal has stopped working, I followed the trouble shooting in the manual. Pulled the plug from the TSM and checked voltage and was getting 12V at the connector when the switch was pressed. According to the manual this means a faulty TSM, replace, so I did. This did not fix the issue, bye bye $125.
I am fairly confident it's not the right signal switch, if I turn on the left blinker and hit the right side swich it cancels the left. This is what's supposed to happen right? I have swapped out bulbs from either side, they're not an issue. Kind of at a loss of what to try next, anyone?
Thanks!!
Old Feb 6, 2013 | 06:51 PM
checkers's Avatar
checkers
Originally Posted by BrusterAZ
Greetings all,
Thanks!!
Replace bulb in r/f signal lamp and then unplug your rear fender tip lite and try the signal again. re-post if that fixes it. replace your fender tip light assy.
Old Feb 6, 2013 | 07:20 PM
BrusterAZ's Avatar
BrusterAZ
Thanks Checkers,
I swapped the bulbs from working left side to right.
Didn't see where I could "unplug" the rear tip light.
The tip light bulb was toast so I tried swapping it with the good bulb from the front and without a bulb, no luck.
Old Feb 6, 2013 | 07:26 PM
checkers's Avatar
checkers
Thanks Checkers,
If you replace the rear fender tip light, it will likely fix your problem. Seldom the front fender tip light is the issue, but possible. Rear light is often the issue.
Old Feb 6, 2013 | 09:51 PM
BrusterAZ's Avatar
BrusterAZ
Are you saying I should replace the rear tip light assembly even if it is working?
Sorry, it's my first HD. Love working and learning on it though.
Old Feb 7, 2013 | 06:10 PM
checkers's Avatar
checkers
The rear fender tip light on Heritages are notorius for causing front t/signal issues. I was hoping you could just unplug it and take the ***'y out of the circuit to try it before installing a replacement. Several other area's can be suspect, but this is where I would go first.
Old Feb 10, 2013 | 04:40 PM
BrusterAZ's Avatar
BrusterAZ
Well.....replaced all the bulbs (again)
Tried with the rear tip light working and out of the circuit.
Still no luck, electrical gremlins suck.
Any other ideas??
Old Feb 10, 2013 | 08:03 PM
oct1949's Avatar
oct1949
Have U ckecked the OIL level in all ur trun Signals..???
Old Feb 11, 2013 | 06:53 AM
BrusterAZ's Avatar
BrusterAZ
Yeah....right after I checked the coolant level.
Old Feb 11, 2013 | 04:36 PM
flst06's Avatar
flst06
Did you check the voltage at the light sockets? Sometimes the sockets ware and don't make contact with the bulbs correctly.
