There was some overlap between model years as it was as "running" change. If in doubt, you can check by removing your crank position sensor and, using a flashlight, look at the flywheel OD. If the sensor trips are machined you have a hot or cold forged unit."
So mine being in the latter part of 2002 (october) hopefully i should have the hot forged crank
