Rocker Tail light Problem.....
Old Feb 16, 2013 | 06:36 PM
Mera308's Avatar
Mera308
Default Rocker Tail light Problem.....
The right turn signal on my Rocker doesn't appear to be working right.
First, the run and brake functions works great.
The LEFTturn signal goes from Run to Run - Bright - Run - Bright and so on for left turn signal.
However, the RIGHT turn signal goes from Run - Dark - Run - Dark and so on. Also, after a few blinks, it goes into fast blink mode.
Also, when the alarm arms, only the left turn signal blinks.
Any ideas?
Thanks.
J.D.
Old Feb 16, 2013 | 07:10 PM
Rodzilla6's Avatar
Rodzilla6
Yep, your screwed! I have a rocker and the original tail lights were bad/leaked water like a sieve...I complained to HD and they gave me a couple of replacements. The replacements have been re-engineered (new rev part number) and have apparently fixed the problem, so far...If you get stuck, I think I have 1 extra light left I can sell you reasonable/email if you need it. They cost like 250 bucks EACH at the dealer...ripoff.
Easy to change, unbolt the rear fender. My plate light went belly up also/water...Good luck. Ps what year is your rocker?
Old Feb 18, 2013 | 06:12 AM
Warp Factor's Avatar
Warp Factor
If any of the three lights is taking on water, and you can get them working again by drying them out, they can be re-sealed (at least for a while) by carefully wicking the flexible, thin type superglue into the joints.
You might also try checking all the connectors.
cptrad
Jul 25, 2010 03:18 AM
finnrocker
Apr 21, 2010 01:44 PM
britter1
Nov 4, 2009 09:04 AM
scubierex
Aug 28, 2009 11:38 PM
