getting big shot longs,a/c and tuner
Old Feb 18, 2013 | 06:48 PM
spinoleo's Avatar
spinoleo
Default getting big shot longs,a/c and tuner
snow isn't leaving soon so getting big shot longs the a/c and tts tuner from local shop.he is going to let me watch how to use the tts and price is very good talked me out of getting the quiet baffles until I ride with the originals and if I want to change later he would change them out at cost plus $10 for labor
Old Feb 18, 2013 | 08:41 PM
QC's Avatar
QC
Can't go wrong with BSLs. Which A/C you putting on? Don't know much about the TTS. Is your mechanic able to tune it? Use a Dyno? Just curious.
Old Feb 19, 2013 | 06:32 AM
BlackSpecial's Avatar
BlackSpecial
Good choice on the TTS. As long as your guy can tune it you should be very happy with the results.
Old Feb 19, 2013 | 07:22 AM
mustang125's Avatar
mustang125
I am doing the same thing. The tts needs a dyno to get a good tune so I went with the dj5 with auto tune. I am not done with the engine mods and don't want to go to the dyno every time I change something. I am using fuel moto's air cleaner as the use a billit backing plate were Aaren Ness uses a stamped steel one. The quite baffles change the tone a little and make it less annoying to the rider. It still is very loud. Have fun!
Old Feb 19, 2013 | 03:33 PM
spinoleo's Avatar
spinoleo
he has a dyno ,but said I could do it with out dyno just down load and autotune the dyno just faster and any changes I make after just look up closest file and autotune 3-5 rides and I will be set
Old Feb 19, 2013 | 03:38 PM
spinoleo's Avatar
spinoleo
the a/c will be a k&n rk series and yes he can use the tts and will show me so if I change anything I will be able to download and change files
Old Feb 19, 2013 | 04:18 PM
FL DEUCE's Avatar
FL DEUCE
post pics when finished.
Old Feb 20, 2013 | 12:48 AM
jbg's Avatar
jbg
Get the quiet baffles now. They bring the tone down a little and make the sound a little deeper. You'll end up wanting them anyway. Save the $10 and do it yourself. On that note, you can do the pipes install yourself. Only takes about an hour. Just need a small jack to get the bike off the ground. You can put the QBs in too.
Old Feb 20, 2013 | 07:22 AM
mustang125's Avatar
mustang125
I hope it stops snowing soon, like predicted by the weather rat,so you can ride. Like said the quite baffles give them a meaner tone. Sounds like you are getting the autotune module with the TTS. this is a good move.
Old Feb 20, 2013 | 02:58 PM
casbar's Avatar
casbar
I had to put on the quiet baffles, but they aren't quiet, but they do take off the edge, without they are bloody noisy, had loads of crap from my neighbours before I put them in
