Bad Electrical Problem
Old Feb 11, 2007 | 05:59 PM
03sporty's Avatar
03sporty
Default Bad Electrical Problem
Hi, It's been awhile since I've been on. I thought y'all will love this one. Any I traded my 03 Sportster for an 01 Softail Duece. i really love this bike. Yesterday my wife noticed that my stoplights weren't working. I checked a few things and couldn't figure it out. So this morning I took it to the dealer. On the way there the dash display went out, the horn stopped working and turn signals as well. The service advisor said it must be a short, but I really don't believe it. Has this happend to anyone else???
Old Feb 11, 2007 | 06:05 PM
liltrk's Avatar
liltrk
Default RE: Bad Electrical Problem
If my memory serves me, all the things you mentioned are on the same fuse. You may have a short, I would start looking in the taillight housing or under the fender. Anyway sounds like you are letting the dealer handle it.
Old Feb 11, 2007 | 06:22 PM
Pilzner's Avatar
Pilzner
Similar thing happenned to me - started with turn signals and then panel lights, etc. Changed the fuse, and when I turned on power it popped again. I disassembled the chrome pods and clutch assembly and finally found I had a wire pinched that was shorting. Wrapped eletrical tape around it and was more careful reassembling. No problems since then.
Old Feb 11, 2007 | 07:16 PM
20NightTrain03's Avatar
20NightTrain03
same thing happened to me
a few monthes after i put my custom LED turn signals on a power wire rubbed thru to the frame (ground)
blew the fuse on my way to work one morning, i look down and see my speedo stuck on 70MPH
Old Feb 11, 2007 | 08:53 PM
Hammer02's Avatar
Hammer02
ORIGINAL: 03sporty
If you don't believe it's a short...what would you believe? What do you expect the problem to be?
Old Feb 11, 2007 | 09:59 PM
03sporty's Avatar
03sporty
I'm not really sure, at first I had running lights but no brake lights. I remove the back light and got my test light and probed the wires. I wan not getting any juice to the brake light wire comming from the front of the bike. I thought mabey it was the brake pressure switch but I didn't test that. I figured that mabey because the bike is fuel injected that it has a computer, and mabey the problem is there. I took it to Harley because I have an extended warranty. I figured hell thats why I got the warranty. Let them fix it. I'll let you all know what develops.
Old Feb 12, 2007 | 02:42 AM
mentor70's Avatar
mentor70
ORIGINAL: Hammer02
ORIGINAL: 03sporty
Things like this are very often "open" circuits, like a loose or high resistance gound path. Or an electrical pin out that has pushed its way loose from the connector that its suposed to be plugged into.
Old Feb 12, 2007 | 12:11 PM
03sporty's Avatar
03sporty
Just found out from the dealer, the problem was caused by an LED liscense plate fram that was not wired correctly. So they will re-wire it for about $100.00 for the whole job. Oh well at least I'll get my bike back today.
Old Feb 12, 2007 | 12:59 PM
tmitchellof PG's Avatar
tmitchellof PG
ORIGINAL: 03sporty
Glad to read it was an easy fix. Whenever you have an electrical problem, the first place to start looking is where there were mods done to the bike.
Tom
Old Feb 12, 2007 | 01:44 PM
20NightTrain03
ORIGINAL: tmitchellof PG
Tom
true dat!
agree 100%
hueckstaedt
May 3, 2018 07:03 PM
agst187
May 11, 2012 04:26 AM
DR. V-TWIN
Oct 15, 2010 09:23 PM
mgbanks
Jun 15, 2009 06:20 AM
catdaddypt
Jan 5, 2007 10:23 AM
