squeek on shutdown?
Old Feb 28, 2013 | 03:18 PM
slim12's Avatar
slim12
Default squeek on shutdown?
I just recently installed a set of v&h slip ons and since then i hear a weird squeek when i turn off the bike and i have no idea what it is... anybody have some input?
p.s. first thing i checked was fluids and there good
Old Feb 28, 2013 | 05:05 PM
Raccerx67's Avatar
Raccerx67
every now and then I get a short whistle that could be described as a squeek I guess, it comes from my throttle body and is related to the engine rotating just slightly backward when the rotation stops and compression causes the engine to slightly back up releasing the pressure. I have heard this same sound from several other harleys also. No idea if this is the sound your hearing but may help ya.
Doug
Old Feb 28, 2013 | 05:17 PM
snip0721's Avatar
snip0721
maybe a bracket rubbing, or baffle sqeeking inside the muffler body?...steve
Old Feb 28, 2013 | 05:23 PM
txphatboy's Avatar
txphatboy
I get a squeak/whistle sound a lot of the time when I shut my bike down. I was told this is common for twin cams and is some type pressure relief valve.
Old Feb 28, 2013 | 05:39 PM
slim12's Avatar
slim12
Doug
That actually makes sense, although i hear it nearly everytime on shutdown, but if it were something else id assume i could hear while its running. Im relieved that it sounds like a common thing
Old Feb 28, 2013 | 06:37 PM
Deucedog's Avatar
Deucedog
My Deuce does it occasionally.
Old Feb 28, 2013 | 06:53 PM
dakotared's Avatar
dakotared
my bikes make a sort of squeek and puff sound if i accidentally kill it on takeoff from a light etc. very embarassing...
Old Mar 1, 2013 | 06:10 AM
bikerlaw's Avatar
bikerlaw
LOL, that noise is totally ridiculous! Its super common as well. Heres a sound clip of my bike making the noise at shutdown with not one, but two different mufflers. Its downright silly.
1:08 and 2:20 respectively.
Old Mar 1, 2013 | 06:12 AM
Notgrownup's Avatar
Notgrownup
It's a happy fart... My XL883c did it and my FLHTC doe it also.
Old Mar 1, 2013 | 06:52 AM
Raccerx67's Avatar
Raccerx67
Good example in the vid, that is the exact sound I was describing... nothing to worry about if that is what your hearing.
