internal wiring handlebars
Old Aug 2, 2013 | 04:24 AM
Stuffa's Avatar
Stuffa
I need some help, I have a 2011 Heritage Softail and have different smaller 4 pin connectors. Does anyone know how to get the pins out of these or do you have to drill the holes out big enough to pull the connectors through the bars
Old Aug 2, 2013 | 06:56 AM
hspring03's Avatar
hspring03
You need to remove the pins as seen in the video.
http://smg.photobucket.com/user/Spri...moval.flv.html
Old Aug 2, 2013 | 07:08 AM
tbonetony06's Avatar
tbonetony06
1 other tip IF you have to splice wires. Stager them so that you don't have 1 big ball of tape and splices right next to each other when trying to pull them thru the bars. I have seen where that has caused the wires to "jam" up inside the bars. I have everything internal now, including clutch and throttle, and it has a very cool and clean look to it up front.
Old Aug 2, 2013 | 10:54 AM
rockinred's Avatar
rockinred
Tony....seen your bars with the internal cables and it looks clean and perfect for my style. I have a hydraulic clutch on mine from factory. I am running 1.50 Flying Apes and want to run the throttles, brake, and clutch through the bars, but it seems almost impossible.
I ran my wires on my bars and I barely could fit that internally. How do you fit those other cables? Is it a huge task? Did you have to drill out another hole on bottom to fit those big cables? How does it look around the base? sorry to hijack, but it is related.
Old Aug 2, 2013 | 02:28 PM
Mr.Softy's Avatar
Mr.Softy
can you buy a wire set or harness to put in the bars? Thinking if I had a set of wires I could put them in without tearing down my bike and not be able to ride. Then I could just switch out the bars and finish the job.
Old Aug 2, 2013 | 03:40 PM
08Nighttrain's Avatar
08Nighttrain
Rider1200: If you just want to install new bars you can buy them prewired so that you dont have to deal with it and just bolt them on.
Old Aug 2, 2013 | 03:53 PM
soft 02's Avatar
soft 02
Shop vac and some ribon work realy well.
Old Aug 2, 2013 | 04:37 PM
Mr.Softy's Avatar
Mr.Softy
These were the bars I was interested in buying
http://www.meancycles.com/store/part...?partID=220431
Does someone make them prewired? Sure would be nice if they did.
Old Aug 2, 2013 | 04:49 PM
soft 02's Avatar
soft 02
http://www.ebay.com/itm/1-1-4-Chrome...f0c6ae&vxp=mtr
Old Aug 2, 2013 | 04:57 PM
Stuffa's Avatar
Stuffa
Thanks for that but they are a different type connector. The ones I have are JAE MX19 sealed four pin. If anyone knows how to get the pins put it would be appreciated
