Finally after months of research, I did a "few" improvements.
S & S CNC Ported Performance Heads
S & S 106 Big Bore Kit ( Flat Top Pistons )
S & S 585 Easy Start Cams
Fueling HP+ Hydraulic Lifters
Andrews Adjustable Push Rods
Timken Bearings, new cam chain tensioners, all paired up with my current performance upgrades: Screamin' Eagle Heavy Breather, Vance & Hines True Dual Head Pipes, Screamin' Eagle Performance slip on Mufflers (gutted with Big City Thunder Baffles installed.) Fuel management by Power Commander, Dyno-Jet PCIII USB. Loaded a canned map (temporary). Will have it dyno'd after break-in miles, but according to S & S specs it should come in at around 115 hp & 112 ft. lbs. torque. Now if I could magically make the snow disappear, I could cure the severe "PMS" and start saving for ????????
Sounds like you're ready for some fun!! Just did a Hillside big bore kit on mine and have been able to only put on about 50 miles, so I feel your pain. Blizzard today. SIGH.
