shotguns
Old Mar 9, 2013 | 12:41 PM
jeepcj33's Avatar
jeepcj33
Default shotguns
Hopefully jd will chime in too. Started up the bike today, hit the switches to raise the shocks and nothing. Thought the relay blew so I bought a new one and put it in and still nothing. Looked over the wiring and everything looks fine. Thinking compressor **** the bed somehow. Anybody have an idea?
Old Mar 9, 2013 | 12:49 PM
Kowan's Avatar
Kowan
Did you check the inline fuse?
Old Mar 9, 2013 | 12:55 PM
jeepcj33's Avatar
jeepcj33
I don't remember a fuse, just the horn relay. When I hit the switches you can hear a click, assuming that is the relay
Old Mar 9, 2013 | 01:04 PM
Kowan's Avatar
Kowan
Unless JD has changed the wiring, there is an inline fuse. If it blew, you wouldn't hear anything since it's on the positive wire powering the system.
Old Mar 9, 2013 | 01:05 PM
jeepcj33's Avatar
jeepcj33
Thx, I will Dbl ck for it.
Old Mar 9, 2013 | 01:16 PM
509Rider's Avatar
509Rider
Check your connections, my connection from the pump to the main harness came loose once and I had to zip tie it together. Problem solved.
Old Mar 9, 2013 | 02:38 PM
spinoleo's Avatar
spinoleo
hope it works once the kids get out of college in a few yrs I will get one
Old Mar 9, 2013 | 06:50 PM
tbonetony06's Avatar
tbonetony06
Call JD himself. His customer service is unmatched. You buy more than just his shock, he stands behind it 100%. If I were a betting man, he'll have you up and running that day or a new part in the mail that same day.
Old Mar 9, 2013 | 09:04 PM
J.D.1's Avatar
J.D.1
Former Sponsor
Default youc an call me anytime at 3233594914
If the relay clicks, then there is power, check for 12 volts at relay harness plug to compressor.
Old Mar 11, 2013 | 10:37 AM
jeepcj33's Avatar
jeepcj33
Not sure what happened, got on the bike today to move it to my new garage to work on it and now everything is working fine. don't know if living here in ny if something froze up or what. Will still get it up in the air and ck all the connections.
