2007 FXSTC Front Wheel Change Out
Old Mar 12, 2013 | 09:00 PM
BLUE_FXSTC's Avatar
BLUE_FXSTC
Stage II
Default 2007 FXSTC Front Wheel Change Out
Anybody out there ever had any experience changing the 21" 2.15 over to the 19" 2.50 sporty wheel. I am considering it for the bigger tire.
Old Mar 12, 2013 | 09:04 PM
QC's Avatar
QC
Check out this size chart to see if it will work.
https://www.hdforums.com/forum/dyna-...chart-out.html
Old Mar 13, 2013 | 03:35 AM
jreichart's Avatar
jreichart
Chart is not entirely accurate since I had a 160/80/16 rear and have a 150/80/16 front. Chart says that shouldn't work at all, but it does. Not running a fender though, so maybe the chart considers that "custom". Anyway....
Blue, you can make almost anything work. Some things to consider are axle diameter, hub width, and spacer sizes. I put a rear wheel on the front of my train. Was able to use stock spacers, but had to have the hub shaved about 1/8" to make the brake work. Other than that, bolted right up. So if you're prepared to do a little work to make it fit.......
Old Mar 13, 2013 | 08:27 AM
BLUE_FXSTC's Avatar
BLUE_FXSTC
Stage II
Chart is good information no doubt, however what I am looking at doing is moving over to the 19" 2.5 from a sporty because #1 I like the MAG look, #2 puts a little more rubber on the ground, #3 fits my budget (custom wheel doesn't).
Was just reaching out to see if anybody has done it that would know the parts off the top that I will need. Don't mind doing a little modification, have access to just about anything machine shop wise.
Old Mar 13, 2013 | 09:36 AM
sagebrush1976's Avatar
sagebrush1976
I'm sure it's not going to be a direct fit due to the hub width of the Sportster wheel (narrow glide) and the Softail wheel (wide glide). As long as you have the correct size bearings in the wheel, everything else can be compensated for with simple spacers. There's a guy running around locally that has the newer Dyna split 10 spoke wheels on his Deluxe......so anything is possible with a little engineering. Good luck and post some pics when you figure it out.
riderboy1961
Wheels/Tires
Jan 30, 2014 05:01 PM
roundy
Mar 18, 2013 10:48 AM
Noble Jim
Wheels/Tires
Jan 19, 2011 09:28 PM
HDJIM1158
Apr 18, 2010 07:03 PM
agapsdiver
Sep 8, 2008 09:37 PM
