OK..I know...I start another thread...I own a Rocker C (2008) and I'm planning to remove the stock turn signal and mirror and install mirrors with LEDs....so after some input from HD Members (Thanks) ....I talked to Badlands and I have two choices now...I can buy the Badlands M/C Product Load Equalizer III (Hardwire) LE-03 Harley Davidson and it will take care of the front turn signal problem for $60 or go with the Badlands Load Equalizer Illuminator Plug In for Rocker and take care of the front and if I decide to upgrade the back turn signals and break light it will take care of it also... all for $115.
I like the option of the illuminator with all the extras and being plug in...but not the price.
I would go for the Load Equalizer III (Hardwire), better price but I don't have any idea of how to wire it, I looked at the bikes owners manual and I don't see a diagram, look underneath the seat and just a lot of wires (don't know what to look for)....so I need help with the installation of the Equalizer III, if I decide to buy this one. I need your input if the Illuminator is worth the extra $55 or not.
Or if the illuminator, plug in option is better.
Any other brands that work on a Rocker C and are plug in (to avoid hardwire it) ?
Pnp beats hard wire (because you are going to cut your harness and solder right?) Spend the extra scratch...easily removed if you get another bike and you can always re-sell it.
ps....you should get rear led clusters, way more visable at night. My best safety mod.
I'll call custom dynamic today and check with them if they have something PNP for my rocker...thanks. If not, Ill go with the badlands PNP (illuminator) I don't want to messed up the wiring and run into costly problems.
Do I have to change the end caps of the turn signals for to red? I might wait until I save some money...and upgrade to LEDs.
