Springer front fender
Old Mar 20, 2013 | 05:27 AM
lolife22's Avatar
lolife22
5th Gear
Default Springer front fender
Ok so I am stationed in Germany. I have a full custom I built myself from a 04 springer...the issue I have is that I removed the front fender but it is required to have a front fender by law here in Germany, Due to the fact that the fender needs to "float" with the action of the suspension it needs to sit high on the wheel...is there anything out there beside machining my own brackets to make the wheel sit tighter to the front wheel? I have searched and searched and I have found nothing. Any help would be great. Thanks...Lo
Old Mar 20, 2013 | 08:31 AM
Rocker_Dan's Avatar
Rocker_Dan
Will a screaming eagle springer fender work?
Old Mar 20, 2013 | 09:06 AM
hspring03's Avatar
hspring03
Kuryakyn made a kit.
http://www.ebay.com/itm/Kuryakyn-Fen...p2047675.l2557
Old Mar 20, 2013 | 03:33 PM
Fesnl's Avatar
Fesnl
Originally Posted by hspring03
These are impossible to find now, I have the same problem on mine..so i ditched the fender. Just take it off in my opinion and plead ignorance if a cop hauls you over..which is doubtful
Old Mar 22, 2013 | 02:47 AM
lolife22's Avatar
lolife22
5th Gear
Thanks for the replies all...yeah I love the look of the bike without the fender and I would love to play ignorance with the German Polizei but at the time of inspection they write down EVERY mod made to the bike and if you get pulled over they inspect the list if one of those items is missing or changed you must leaver your bike at that location until the part can be located or put back on etc....it is ridiculous here. You have to carry a packet of crap around with you just in case you get pulled over....loud pipes are the biggest thing here....you can't have them. Companies here have gone as far as placing electronic butterfly valves in the pipes so that you can turn off the sound with a push of a button..very expensive and shows ingenuity but still ridiculous all the same. I built my bike to be bare bones custom and now I have to "stockify" it to be able to ride it...needless to say I am irritated to say the least.
ten90seven
Sep 8, 2014 08:20 PM
LiveFree55
Nov 21, 2013 01:07 PM
cherrick
Feb 9, 2012 12:13 PM
96SpringerSoftail
Jul 26, 2008 12:56 AM
96SpringerSoftail
Jan 23, 2008 06:13 PM
