I'm going to purchase a Harley and am torn between the Deluxe and the Fat Boy. I personally like the looks of the Deluxe better, but am concerned about the low ride height.
As background info, I used to be into sport bikes and raced at the club level for a few years. Then switched to an Electra Glide for some touring. Then switched to a BMW GS for some touring with an off-road twist. Now I just want to tool around town and make the occasional day trip to the Blue Ridge Parkway.
I fully understand that these bikes are not intended to carve up the curves, but I don't want to be scraping every turn while riding at a casual pace.
Although I ride a Heritage, if you want to "tool around town", IMO a Deluxe would be a more comfortable ride than a Fatboy. If you wanted to "carve up the curves", I'd recommend the Fatboy. The difference in ground clearance between the two is slightly more than 1/4" which is unlikely going to be the difference between scraping the floorboards and not scraping them. Scraping them will happen. There is no preventing that. I'm sure you are aware that ground clearance can be increased by changing the tire size and (probably to a lesser degree) using an air suspension like Shotgun shock.
BTW, I hope I was easy on you. Don't get used to it .
Yeah the fatboy is going to have more clearance but not enough that it becomes a decision maker. You should go with which ever one you like more and it sounds like you like the deluxe the best. I say go for the deluxe and just get use to her. I went from 09 and up tourers in which I rode pretty aggressively in the corners I just changed the way I ride when I got the softail and I haven't scraped yet.
If you get a Fatboy, Heritage, or Deluxe and want better ground clearance you can replace the boards with forward controls. The boards are going to scrape if you ride it very aggressive at all. Find a set of oem forwards on eBay and it will be a cheap fix.
I bought my first Harley which was the Deluxe a year ago coming off sport bike. I scraped the boards liked crazy at first until I was able to know the limits of the bike. After a year I barely scrape if at all. I ride alot of canyons on the weekends. I would like to to get the shotgun shock to increase ride height. Not sure if it's worth the money to get a extra inch or so in height.
Between the fatboy and deluxe both bikes will scrape and not much difference in performance. A dyna would give you greater clearance and performance but I didnt like the rigid mounted engine.
Did you type something different than you were thinking? Softails have rigid mounted engines, Dyna's do not.
I have never had a problem with the Deluxe clearance and I ride twistys and mountain passes all the time. Love the bike once I dumped that stock seat which nearly sits you on the tank and added highway pegs & apes. SJ Ron
