samson true duals
Old Apr 9, 2013 | 02:31 PM
bikerlaw's Avatar
bikerlaw
Dang, how's that for an answer. There's a reason I run the Samsoms on my Fat Boy, and this thread pretty much sums it up.
Old Apr 9, 2013 | 07:14 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I just recently put Samson True Duals (28.5" long tails with removable baffles) on my 2012 Heritage. Everything needed came with the kit.
Did not need different sensors, did not need any wire extensions.
It came with the different bracket for the coil (which I did not use because I had already relocated my coil) and it came with a specialized shift linkage, which I did use.
I have a few hundred miles the bike with these pipes, and love the sound!
It was also very easy to tune, not only a good looking and good sound system, but one of the better designed set-ups for exhaust gas flow.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 9, 2013 | 07:20 PM
snksknrZ28's Avatar
snksknrZ28
Originally Posted by Samson_tech
Our True Duals will fit your bike. The pipes have the O2 sensor bungs in the stock location and they are stock size. The pipes come with the coil bracket and the shift rod linkage just like the other member stated. As always the best advice I can give you is just give us a call and we will always be able to quickly guide you in the correct path to choosing a great set of pipes.
I guess I should have been more specific when I asked. The pipes are used and are off a 04 or 06 deluxe and was wondering if the mounting points would be the same. I will call Samson with a part number once I get it from the guy that is selling the pipes.
Thanks for all the helpfull input
Rumbles
Jan 18, 2014 04:52 PM
Northbound Southerner
Dec 4, 2013 10:39 AM
m24shooter
Nov 15, 2010 12:02 PM
sortasuave
Aug 26, 2008 07:52 AM
achog88
Jul 13, 2008 03:50 PM
