After Stage 1, bike running HOT...
Bike is a '13 Slim.
I just had it into the dealer for a Stage 1 upgrade and at the same time I had the 1K service done (all synthetics).
The Stage 1 consisted of a set of V&H Big Shots, and S&S Super A/C, plus I purchased the SERT which they say they used to download a new map.
Now my understanding is (and they told me this beforehand as well), that the new map is of the "canned" variety but it would in fact enrich the fuel/air ratio somewhat, resulting in a little more power and cooler running.
The bike runs great, so no complaints there.
But I will say that if there was any increase in power as a result of this work, it's negligible.
I've seen people say how their machines felt "like a new bike" after tuning.
This one runs and feels pretty much like it did before all this - just louder.
Now... since I got it back, I've run three tanks of gas through it, and noticed two things:
#1) It's running considerably hotter that it was before (noticeable mainly in stop-n-go traffic) - so much so that I'm now worried about what this may do to the bike if left as is.
And this was on a few 70° days, I can't imagine how hot this will feel in summer.
#2) My MPG has jumped considerably, by 4MPG.
I know because I keep meticulous records, to the point where I enter gas receipts into an Excel spreadsheet.
So clearly the bike is still running lean, maybe even more now than before.
I'm assuming this is NOT normal. If anything I would have expected my MPG to drop a little.
So what can I expect, or ask the dealer to do to correct this?
On a side note, since I have the SERT, can I go ahead and buy the cables and software and play with this myself - or am I forever stuck at the dealer's mercy?
IOW, do they use any special dongles or equipment to make changes that I can't?
not too sure about the tuning aspect of the sert.
I went with the PV and the Fuel MOto loaded tune was the same as what you described. It wasn't until i sent it back and forth to jamie and had him fine tune my logs that it really improved.
You may want to get that tuned right.
Pull ur o2 sensors and see if its white.
FWIW, I also had the SE Pro Tuner on my '09 Street Bob and I had to bring it back to the dealer three times for them to make adjustments on the Dyno to get it right. They didn't charge me extra cuz I paid for the Dyno tuning up front when it was installed by them.
That and the dealer (in a moment of honesty) pulled me aside and told me it wasn't really necessary until I get to Stage 2, if I do.
The key word here being necessary.
I know, I know... I realize this is like opening a can of worms, like getting into a discussion about oil - a lot of strong opinions either way.
I realize a dyno tune is the best way, but they told me that if it was properly tuned at Stage 1, that I should see noticeable performance improvement, enough so that the added benefits from a dyno -might- not be worth the extra money - considering in my case that it was just a fine tuning on an otherwise stock engine.
They went on to say that dynos mainly benefited people who have had significant engine work done (at least cams).
He told me to save my money.
..and this was from a dealer I trust, whose main purpose is to make money...
Think about that - they had two choices here, [1] to either play me for a sucker, or [2] tell me straight up.
I believe they opted for door #2.
We'll see, after all, they did offer to make adjustments if needed.
I'm mainly just wondering if my initial results are typical...
The canned map only get's you close, however even with the dynotune, the stage one didn't impress me all that much having come from a 88" stroked evo and a 96" S&S evo, both put my 103 twinkie to shame. If you want to wake that motor up, get the heads done and throw cams in it, when it's breathing properly it will run properly
I would investigate FL-ViEDs as well. Search here on the forum all about them. That's what I have running on my Slim and it's running great. Significant cool down, richer running, bike is smooth and quick off the line. You really can notice it. Cost a little over 100 bucks and you do a very easy install.
I was quoted 800 bucks for a dyno in L.A. That ain't chicken feed for a few extra HP.
