Springer Breakout???
Old Apr 12, 2013 | 08:42 PM
acman308's Avatar
acman308
It'll be nice when done.......
But i was hoping someone had already put a springer front end on the breakout.
Old Apr 25, 2013 | 09:29 PM
JDeCo21's Avatar
JDeCo21
Do you happen to have the part numbers for the swingarm, primary offset kit and also the rear fender and strut? Interested in doing the breakout swap on my blackline . Thanks!
Old Apr 25, 2013 | 11:40 PM
m i k e's Avatar
m i k e
those wheels would look really good blak
makin this thread subscribed
& yes team red OWNS
Old Apr 26, 2013 | 12:36 AM
EZSkankin29's Avatar
EZSkankin29
Gonna be sweet. Solid choice.
Old Apr 26, 2013 | 04:48 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by rockinred
The swing arm can be used from either rocker, 09 cvo springer, or all breakouts. They all use the same swing arm for those models.
Doesn't that swingarm only fit those frames (the Rocker frame)?
If so, might need a Heartland swingarm.
Old Apr 26, 2013 | 10:15 AM
Wide_Open's Avatar
Wide_Open
Lots of work ahead but I'll bet it will sure be worth it. Can't wait for the after pics.
Old Apr 26, 2013 | 11:05 AM
schlacker's Avatar
schlacker
Gonna be awesome...can't wait for the pics & see the final outcome. Good luck!
Old Apr 26, 2013 | 11:06 AM
Koshman32's Avatar
Koshman32
That was going to be my question as well.
Old Apr 27, 2013 | 06:26 AM
rockinred's Avatar
rockinred
As far as HD and softail.....those are the only swingarms that HD made that will fit that rear wheel. Then the spacers would be the same and the belt will line up for pulley.
I've heard of the heartland kit, but I don't think you can just buy the swingarm. If so, I am sure that one will work too. The mods might be a little different than the HD swingarm, but you get a fender too.
Scooter, where you at on this? What have you found out?
Old Apr 27, 2013 | 11:09 AM
scooter223's Avatar
scooter223
Rock,
Haven't even started it yet. I need to find a good primary offset kit first before I start taking stuff apart. Also would like to find a CVO springer rear fender and struts as well. I will probably put the front wheel on pretty soon, which will look ok with the solid back wheeel for the time being.
JS
