I have a set of DNA mammoth 52 spoke wheels. The front wheel has a leak around the base of the valve stem. Do you know if valve stems are available from DNA ( their Site is down) or should I just get a tube. If I should get a tube, what size and where would be a good spot to get one? Thank you very much!
This is the first problem I've had in years with these wheels, I don't really want to go the inner tube route if I don't have to. IIRC The RiM is 21 x 3 or 3 1/2 inches. Thanks again
