Starter problem...help
Old May 2, 2013 | 07:39 PM
hdmc cruiser's Avatar
hdmc cruiser
Stage II
Default Starter problem...help
Having problem starting my 2007 Heritage Softail.
When I turn on the key, nothing happens, as if no connection. Just like I never turned on the key. Checked the On/Off switch, checked and not in gear, etc. I thought it was the battery, but checked it out and was good as was a new battery. Checked all connection, and voltage. So, for some reason, I tried putting it in gear, and rock it back and forth a few time. took it out of gear and turned on the key and it works and will start. If I ride it and make a lot of stops, it will crank back up with no problem. Then let it set at home a day or two, and have to do the rock back and forth again. Why is this happening, and how can I fix this weird problem ?
Thanks for any help...I am new to the HD Forum.
Don'
Old May 4, 2013 | 10:39 AM
hdmc cruiser
Stage II
Default Starter problems
Bump this up..as no answer yet...HELP ...anyone help find solutions?
jorgester02@yahoo.com
Apr 3, 2024 06:16 PM
68_sporty_89
Ironhead
Aug 5, 2012 12:52 AM
arizonapete
May 24, 2011 03:13 PM
2kanzam
Jun 27, 2010 04:37 PM
yellowdafish
Jul 14, 2009 09:29 PM
