power cones
Old May 7, 2013 | 12:31 PM
mag11581's Avatar
mag11581
Default power cones
Are power cones worth the time or effort?
Currently I'm running Kromeworks slipons on my 2010 Fatboy.
Stock air cleaner and stock map on the ecm.
Every once in a while I get a pop on decel. Will the cones prevent this?
Will the cones give a little boost to the torque?
Old May 7, 2013 | 12:52 PM
Josewales's Avatar
Josewales
Last year we did dyno combos with TQ cones and baffles. Turned out the TQ alone outperformed with baffles and baffles alone. I believe my 255se cams had something to fo with it being low rpm TQ.
Old May 7, 2013 | 01:16 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
You'll get a much larger low and mid range gain with Thunder Torques Inserts than cones.
Less expensive and easier to install too!
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 8, 2013 | 07:49 AM
cgmartine's Avatar
cgmartine
Sorry DK, but your inserts are useless.
Old May 8, 2013 | 09:42 AM
Ramboamt's Avatar
Ramboamt
And why would you say that?
Old May 8, 2013 | 03:12 PM
lionsqrne's Avatar
lionsqrne
I haven't had it on a dyno yet but when I switched to samson true duals 39 inch with no baffles I installed the TQ's. I was shocked at how much torque was there from them. My bike was dyno tuned for the Andrews cam, SE intake and a Fat Cat with Heritage muffler.
I hardley ever get any decel pop or back fire. Still getting it dyno'd but it actually runs great on the current map right now.
Old May 8, 2013 | 03:13 PM
lionsqrne's Avatar
lionsqrne
You obviously don't know how to read the charts.
Old May 8, 2013 | 03:20 PM
SethLee11's Avatar
SethLee11
won't help popping... will probably make worse as heads won't scavage. Popping is ok, that means your bike is tuned right. May help your torque a little bit, but cams will help more...
Old May 8, 2013 | 04:08 PM
Jesse_81's Avatar
Jesse_81
Anyone notice something fishy with the softail (2nd) Dynograph? Torque and HP don't cross where they're supposed to.
Old May 8, 2013 | 04:31 PM
Warp Factor's Avatar
Warp Factor
Yeah, you're right. Somethin' fishy going on.
