07 Softail Exhaust -- "True Duals"
Old Feb 21, 2007 | 12:08 PM
zeeb's Avatar
zeeb
6th Gear
Default 07 Softail Exhaust -- "True Duals"
New to the forum but not new to the sport.
I have heard that "true dual" exhaust systems (ones without interconnecting pipe) exhibit a dip in the torque curve -- probably in the mid rpm range. Vance and Hines claims no torque loss across the entire rpm band (with their re-map) but will not share a dyno chart. Does anyone have a torquegraph with either thenew Vance and Hines true duals or the Samson versions -- plus alow restriction air filter (only these mods)? What fuel injection module and calibration strategy (in general) was used (i.e. powercommander, a/f calibrated to 13:1, spark set to mbt)? Also, since the left side of the bike with these exhaust systems has routing under the seat and next to the oil tank -- any instances of high heat to the rider, or higher heat being input to the oil tank?
Old Feb 22, 2007 | 01:48 AM
purple haze's Avatar
purple haze
Default RE: 07 Softail Exhaust -- "True Duals"
06 C.V.O. 103 fat boy, s.e.r.t, K&N, 8mm plug wire's, no mod's to motor, D&D Boarzilla 2 in 1 with performance baffle, not cheap, you can go to there site and they show spec's and dyno's for all harley's, at 1000 mile service had dyno to bike, it's not the fastest, but it goe's fast enough for me, also this is rear wheel H.P & TOURQE.
[IMG]local://upfiles/24725/8AFB9E2EA84B4B63B81B974C61F5C16D.jpg[/IMG]
[IMG]local://upfiles/24725/2A343295CA3444958E16558EF86E03F1.jpg[/IMG]
Old Mar 6, 2007 | 02:01 PM
zeeb's Avatar
zeeb
6th Gear
Thanks Mr. Hendrix!
Old Mar 6, 2007 | 06:16 PM
purple haze
ascuse me while I kiss thesky!!!!!!!!!!!
[IMG]local://upfiles/24725/9C4AE25897D84FC2B515FBC164731401.jpg[/IMG]
Dmopower
Apr 6, 2017 06:51 PM
Cloud09King
Sep 16, 2008 07:37 PM
shartflhs
Apr 19, 2008 03:48 PM
vette03
Exhaust System Topics
Apr 11, 2008 09:02 AM
sweet street glide
Feb 29, 2008 08:36 PM
