Springer Springs
Old May 18, 2013 | 08:43 PM
aclass's Avatar
aclass
Default Springer Springs
Does your front end make noises when you bounce or exercise the suspension?
I have a 2000 FXSTS with 44K and other than checking the neck bearing and inspecting the rockers at front tire changes, I've never had to do anything to it. Still rides great. However, with the bike stationary and forcing the springs up/down, it sounds like a piece of farm machinery in and around the springs. Just want to make sure yours does it too.
Old May 18, 2013 | 10:26 PM
NoRegerts's Avatar
NoRegerts
Mine did while it was breaking in, but rolling at 22k the front end is usually quiet. From time to time I get a squeal or a rattle on hard bumps. Only had to adjust the rockers once so far and fall out once too. It's been relatively maintenance free.
Makes me want to check when I get off work lol. I'll hit you back up.
Old May 19, 2013 | 12:35 PM
NoRegerts's Avatar
NoRegerts
Nope, it squeaks. Just didn't notice.
Thanks...
Old May 19, 2013 | 02:31 PM
Vic Bronco's Avatar
Vic Bronco
My Crossbones would squeek a bit in th efront end when the front end was shifting up and down. I'm pretty sure it's just the springs rubbing against the other components, I never worried about it and just took it as one of those things with a springer front end.
Old May 19, 2013 | 02:45 PM
SPRINGER's Avatar
SPRINGER
I have a 2005 Springer with about 68,000 on it and never noticed any noises while stationary or backing it out from under my carport when I am getting ready to ride. I don't know if it is common or uncommon, I just know mine hasnt't given me any issues so far.
Old May 19, 2013 | 03:36 PM
aclass's Avatar
aclass
Thanks for all the replies.
It's about time to change the front tire so I'll likely go through the front rockers pretty good this time.
Old May 21, 2013 | 08:44 AM
Skeezmachine's Avatar
Skeezmachine
My Crossbones' springs have always squeaked some but I only hear it when the bike is not running. Also, I really have to bounce it pretty hard and deliberately try to get the front suspension to articulate in order to hear it. I don't hear it at all if I am just moving the bike around in the garage or whatever. Going down the road it becomes a non-issue.
It's never bothered me that I can hear the noise when you jump on it. It a bunch of metal and springs put together in almost the same way that they have been doing it for years! I wouldn't expect it to me devoid of noise and honestly, to me it's part of the charm of a Springer.
Old May 21, 2013 | 08:53 AM
SprungDave's Avatar
SprungDave
Every once in a while, give the inner springs a shot of WD-40, using the straw, between the coils of the larger, outer springs. The springs will rub against each other and at the ends of the springs where they meet the bushings. That is the source of the spring squeak. They just need a dash of oil. Once done, the squeak will be gone.
Trust me, I KNOW springs....
That's why they call me:
Old May 21, 2013 | 05:28 PM
imboden's Avatar
imboden
Mine doesn't give me any at all. Last set of springer forks I had did, but did not bother me at all....
Old May 23, 2013 | 01:26 AM
rlowride's Avatar
rlowride
i get a vibration sound and some of the squeal.. the buzz bugs the **** out of me, but i cant trace it down....
i need to learn to do the maint on mine... i think i need to do the neck bearings too.. i am usually mr fix it, if i can watch or help someone do the job first....
edjack
Apr 2, 2014 11:51 PM
twowheelsforever
EVO
Nov 16, 2008 05:03 PM
Tralfaz
Aug 27, 2008 05:49 PM
Fxstsb6
Aug 2, 2007 05:05 AM
pwarrick
Aug 25, 2006 01:01 PM
