Night Train headlight dims intermittently
Old Jun 25, 2013 | 11:20 PM
Mr. Lucky's Avatar
Mr. Lucky
Originally Posted by soft 02
Could be the ground wire to your tripple trees. Remove it and clean n re install it.
No, that actually can't be the problem. That jumper wire is a standard part of the Softail wiring, but is only required for bikes running handlebar mounted turn signals, which no Night Train ever had. I've been running without one for years.
Old Jun 25, 2013 | 11:24 PM
soft 02's Avatar
soft 02
So I can remove that dam thing?!
Old Jun 25, 2013 | 11:26 PM
soft 02's Avatar
soft 02
Well if all other wires are confirmed good the I think maybe the VR might be going out. When mine went out my headlight would pulse going down the freeway. Just a guess. At idle mine was also testing at 14v.
Old Jun 26, 2013 | 07:20 AM
dieselsmith's Avatar
dieselsmith
Wouldn't a bad voltage regulator screw up all the electrical stuff? There seems to be a ground wire in the 3 wires in the light itself. I assume 1 for hi/low and ground. It does do it on high and low beam. Kind of slow to switchover between beams too (hi-low or low-hi)
Old Jul 16, 2013 | 02:41 PM
dieselsmith
Well I took the headlight apart and the terminals werent corroded but i put a little grease on them anyways. So now where do I do with it?
Old Jul 16, 2013 | 02:42 PM
dieselsmith
And it still did it on my way to work last night.
Old Jul 16, 2013 | 03:03 PM
UT-rckr's Avatar
UT-rckr
Have you ever actually put a new bulb in? Start with the easy things
Old Jul 16, 2013 | 05:41 PM
dieselsmith
No I haven't. What is the bulb number? Maybe i'll get one of the fancy white light ones. Can you get them from the auto parts store?
Old Jul 16, 2013 | 06:12 PM
soft 02's Avatar
soft 02
H4 is the bulb.
Old Jul 16, 2013 | 08:25 PM
QC's Avatar
QC
See if you can find an Osram Nightbreaker. Put out awesome light.
