HELP...please!! V&H install problems
Old Jun 3, 2013 | 11:59 AM
r0ck3r's Avatar
r0ck3r
Ok, so according to V&H there's a gasket between the pipe and exhaust port which I did not see on either exhaust ports when I took the old pipes off. There rear pipe is hard to get threads thru the flange to get the nuts on. I find it hard to believe to use the recommended SE flat gaskets recommended would make that much of a difference. Off to HD to get new gaskets and circlips.
Old Jun 3, 2013 | 03:53 PM
PLHbrian's Avatar
PLHbrian
I put these pipes on over the winter and it wasn't easy. When you get the new gaskets take your time to get them in evenly with out crushing them. On my second attempt I used a flat washer just big enough to cover rhe gadket which allowed me to work them in. Keep it all loose until you get the nuts started all the way around. Torque spec on the header bolts is 110-120 INCH pounds. Not very tight at all.
If you can get a second pair of hands to help it will make it go a lot easier. Just take your time and it will be worth it. They sound great.
Old Jun 3, 2013 | 07:17 PM
r0ck3r's Avatar
r0ck3r
Well, I just found out the hard way that the HD Rocker is undoubtedly a CVO...this I did not know. I have the wrong pipes for my rocker. Here's hoping that the place I ordered them from last sept will exchange them for the correct pipes
*sigh*
Old Jun 3, 2013 | 08:26 PM
haak30's Avatar
haak30
Dude, let me know if you need any help!
Old Jun 3, 2013 | 09:24 PM
m i k e's Avatar
m i k e
say what?
do you know what cvo means?
custom vehicle operations
the rocker is def. not that who said this?
chit mang good luck
Old Jun 4, 2013 | 12:31 PM
r0ck3r's Avatar
r0ck3r
Yea if you go to the V&H site and click on the CVO option for pipes it has the exact same part number that the guy at V&H said I needed. I didn't think rockers were CVO's either. I guess another call to them is in order to tell them that their website is very misleading.
Originally Posted by m i k e
say what?
chit mang good luck
Old Jun 5, 2013 | 09:39 AM
r0ck3r's Avatar
r0ck3r
So the vendor that I got the pipes from, One Stop Moto, has gone out of business. Anyone in need of some pipes?! FML
Old Sep 17, 2013 | 05:44 AM
elfuegohd's Avatar
elfuegohd
6th Gear
Yes, correct PN from Vance&Hines ShortShots for a Rocker is:
V17929 - Rocker CVO 09 ShortShots...
Just got them for my 08 FXCW rocker!
Good luck!
ryda
Dec 4, 2017 09:43 PM
SiggerTX
Aug 21, 2016 02:10 PM
HDRusty
Jan 5, 2010 11:21 AM
classicjade01
Oct 24, 2007 09:38 PM
Dalton
Exhaust System Topics
May 19, 2007 10:57 PM
